Metco Idler Pully
Old Aug 18, 2004 | 10:34 AM
PBGas's Avatar
My squeak got worse after I installed my FTVB. No problem though, that mod was totally worth it!
I'm going to order that Metco setup from Tim as well shortly!
Paul G.
Old Aug 18, 2004 | 12:41 PM
MaxPower's Avatar
Of course. Your engine is dropping RPMs faster now on the shift, slowing the accessory belt quicker, causing the "chirp" or squeel.
Old Aug 18, 2004 | 05:05 PM
Fast Gator's Avatar
Originally posted by 03LightninRocks
I probably wouldn't mention the idler set up if I did seek warranty work from them.
Rocks
Me either
Old Aug 18, 2004 | 06:37 PM
wydopnthrtl's Avatar
Why do you guys think the belt squeek is a "problem"?
Rich
Old Aug 18, 2004 | 06:44 PM
Unoid's Avatar
from a young newb to greese monkey aciton, like me, what exactl is this darn mod useful for? I got a 99 L and I am wondering, why in hell would I need this mod? Anyone care to tell me why?
Old Aug 18, 2004 | 08:38 PM
Blown5Pnt4's Avatar
hey guys I have a question about this as well. I have a 2001 Lightning with a stock upper pulley and 2# lower pulley. But lately if I nail it in the truck, and let off just before the tranny shifts, I hear a loud squeal as if coming from the belt......would this set up eliminate that squeal for me ?
Josh
Old Aug 18, 2004 | 08:50 PM
Fast Gator's Avatar
It helps with aftermarket (smaller) blower pullies. A smaller pulley has less belt wrap. The Metco pulley "wraps" the belt around the blower pulley more, so you have better grip
Old Aug 19, 2004 | 08:52 PM
Suavy's Avatar
Here is what I use.
Old Aug 19, 2004 | 10:54 PM
PBGas's Avatar
So then by accesssory belt, the one that the alternator runs on is what you are referring to? Sorry....just a bit confused on that. I've always understood it as there being the two setups on the truck....the supercharger belt and the accessory belt...hence why I was asking.
Paul G.
Old Aug 20, 2004 | 07:03 PM
Suavy's Avatar
You can fix the accessory belt squeal by first verifing that your belt is good and then by changing the tensioner.
Suavy
