Am i really doing this....nitrous question
Old Jul 31, 2004 | 11:47 AM
FineLineMtrSprt's Avatar
Question Am i really doing this....nitrous question
yeah i gues si am really askign this. Just for *****s and giggles i guess. But im considering running a small shot of spray<50 shot more than likely>. I was wondering where are you guys putting the nozzle at in the intake tube. On the bottom...from the side...in the plenum. Also you think a 4lb with a mild tune<prolly 17 degrees at the most> with a 50 shot used every now and then would be ok on a stock bottom end? Im not trying to set any records just havin fun i guess. Of course i would only be using it every now and then..maybe 3-4 times a year at the track..lol...well thats what im telling myself. I have played with spray and told myself i was done with it forever. but my buddy has a kit just laying around he may let me borrow. . Let me know what you guys think.
Thanks, Vince
Old Jul 31, 2004 | 12:45 PM
LatemodelRacer2's Avatar
You should be fine with a 35-50 shot. My nozzle is in the rubber boot right now but im gonna try and mount it in my phenolic spacer. Im just not sure if the phenolic will tap and thread up.
Old Jul 31, 2004 | 01:06 PM
Rob_02Lightning's Avatar
Can't beat the PSP plate, it's a perfect location.
I used it for a couple of years
Unfortunatly not every nozzle out there will work out with it,
when I switched to the Race Tested Kit they happen to use a very short Nozzle so I had to find a new location.
I decided to drill the Upper Manifold and tap it, it prob took less than 3 minutes start to finish once the TB was off.
I feel it's the ULTIMATE LOCATION
I know they always say measure twice, cut once, BUT THIS IS ME WE'RE TALKING ABOUT HERE so yes that is an extra hole and plug on the pass side of the Manifold you see to the far left of the picture. It would have worked fine, but if you look at the inside view you can see that our manifold takes a sharp turn to the right, I would have been spraying into the dead corner.
By moving it to the Drivers side (where it is now) the turn works in my favor and I end up with the perfect spray right in the center of the manifold. Works for me.....
And yes your safe as long as you don't over do it
Old Jul 31, 2004 | 03:12 PM
wydopnthrtl's Avatar
PLace the nozzle as far up stream as you can but yet not in front of the MAF.
Rich
Old Jul 31, 2004 | 03:32 PM
Ok thanks guys i wsa thinking about putting it on the drivers side of the inlet boot so it could be easily taken off when i need to. But thanks for the ideas. I was figuring a 35-50shot and not a damn horsepower more. Of course i would be hooking up the purge. I know its kinda ricerish but oh well.
Old Jul 31, 2004 | 05:17 PM
tallimeca's Avatar
NOS
Probie just ran his truck today with his new nos sestup. 01 w/ 6lb lower, filter. Usually runs 12.9's in the heat we had today. Made a 12.4 pass on a 50 shot. So on the usually 12.5 days he runs in the fall.....knocken on 11's all day long hopefully.
JLP has a nice tune for a 6lb lower, 93 fuel, and a 50 shot.
Al put out over 450 hp and 630ftlbs!!!
Old Jul 31, 2004 | 06:44 PM
Hmmm....and ill be making a trip to JLP on the 14th to drop off a buddies Lightning for tuning. Doe JLP do Diablo..i cant remember.
Old Jul 31, 2004 | 06:49 PM
probie's Avatar
Yea he does. I have his nitrous and street tunes for the predator.
Old Jul 31, 2004 | 06:51 PM
Double Hmmm....wonder if can get it all hooked up without the wife knowing..lol
Old Jul 31, 2004 | 07:22 PM
JimJr's Avatar
Hey probie
would you and your buddy that hooked up your stealth setup be willing to hook one up for me? I;m right outside boston
JPaskell@Bridgew.edu
