tube attached to rubber boot at end of throttle body? help!
Old Jul 16, 2004 | 08:27 PM
birdy111's Avatar
so i disconnected everything past the tb and took it all out (to clean TB) and noticed this tube that appears to lead into nothing... Kind of just snakes back toward the firewall. I looked and it doesn't appear to connect to anything but i might have missed something? am I just being retarded and its supposed to be like that? or am i missing something?
Old Jul 16, 2004 | 09:05 PM
Bryce_Thomason's Avatar
if it is the small line it probobly goes to the boost dump solonoid. (bolted the the side of the supercharger) it deff. needs to be hooked up
Old Jul 16, 2004 | 09:07 PM
BDAZSVT's Avatar
One leads to the IAC area and another to the drivers side valve cover (pcv)
Old Jul 16, 2004 | 11:55 PM
EZGZ's Avatar
How many miles do you have on her now birdy and did you find any oil in the TB?
I didn't want to wait so I got the Lightning Enterprise PCV kit in right away.
The valves go in each valve cover vent.
The other big line is where you get the air for your idle circuit and that gets cruddy eventualy.
http://lightning-enterprise.com/pcv.html
Old Jul 17, 2004 | 01:00 AM
birdy111's Avatar
ez i think it was the air one.. that doesn't attach to anything at the other end does it?? it started up and ran fine and didnt throw any codes so I'm assuming its alright. Just broke 26k on the L... there were a few built up deposits so i cleaned out all the gunk with a little degreaser and a terry cloth and I think i'm going to order that PCV kit.
