Why is the shaker so expensive?
Old Jul 16, 2004 | 12:44 AM
LightningGuy's Avatar
Isn't the famed shaker hood based off of the stock hood? Is it expensive because the OEM hood from Ford is?
Old Jul 16, 2004 | 01:34 AM
Ron Rairie's Avatar
I would have to say it's due to the addition cost of the manufacturing of the shaker scoop and brackets.
Old Jul 16, 2004 | 01:36 AM
Unoid's Avatar
Pfft I could make a shaker hood with 30$
get a dremel and cut a hole in the stock hood, then get a rubbermaid bargade bin and but that up and throw it in hte middle!
Old Jul 16, 2004 | 01:45 AM
Ron Rairie's Avatar
I'd like to see you do it Red-neck Roy.
Old Jul 16, 2004 | 01:58 AM
Unoid's Avatar
Hey watch it :P
I'm lucky to have a modded 99 L at the age of 21 :P
Old Jul 16, 2004 | 02:34 AM
So is an OEM Ford hood the base for the aftermarket shaker hood? I'm also wondering because I would like to know if it is aluminum or not.
Old Jul 16, 2004 | 03:35 AM
31Charlie's Avatar
Where did ou get that grill, its awsome.
Also Ive always wanted a shaker hood, but I want an agressive one. Kinda like the Mach 1, where the shaker is one a good size bump in the middle of the hood not just the normal flat stocl hood. IS this possible?
31C
Old Jul 16, 2004 | 03:52 AM
Coldie's Avatar
Cost
Shaker hood is not based off anything. It's a full fiberglass piece.
Weight is about 3 lbs more than a stock aluminium hood.
They are expensive because it's a huge chunck of Fiber and it's very low production.
Besides. It will cost you at LEAST $500 to paint it... a new hood is never a cheap endeavor.
Coldie
Old Jul 16, 2004 | 10:49 AM
Ron Rairie's Avatar
31C
31C, the shaker hood is the only two piece hood available.
The shaker is just a tad bit smaller than the Mach1 hood.
The grill is an 03 HD.
You're right on the money Coldie. I paid 550.00 for prep/paint/install.
Old Jul 16, 2004 | 01:28 PM
zachary.taylor's Avatar
RON...
Grill question... you said the grill you have is from an 03 harley? Is it a direct fit top and bottom?
Old Jul 16, 2004 | 01:31 PM
Ron Rairie's Avatar
Nope. j-jent custom lower. The lower will set you back $115.00
Old Jul 16, 2004 | 01:41 PM
so where can i go..
to get the grill that you have?
Old Jul 16, 2004 | 01:47 PM
Ron Rairie's Avatar
You can either spend 350.00 buying one from ford or
buy a used from somebody off one of the HD boards.
Feel free to email if you have any further questions
rrairie@sbcglobal.net
Old Jul 16, 2004 | 01:48 PM
Jkstang78's Avatar
Can someone please post a link of where you got the hood from I really like that hood. Is it ony 3Lbs heavier then the stock hood. If so that is not bad at all. Thanks Jason
Old Jul 16, 2004 | 02:11 PM
Ron Rairie's Avatar
LFP sells them for 850.00 shipped. 3 LBS heavier is not true.
I believe it weighs between 30-40 lbs. I don't really recall.
