Swapped To 03 6 Disc In Dash Please Help!!
I just did a 03 6 disc in dash changer, from an 03 L, to my 2002
Its working fine, but I thought you could plug in the rear changer and that would work too??
I did a search, but cant seem to find my answer
any help would be appreciated!!
Matt
Matt
Originally posted by KP1
I recently did the same swap. Just push the cd button on the front of the radio twice and it will control the changer behind the seat.
Thanks, I was fortunate enough to have the previous owner call me!! Stalian999!! and tell me that, then I went and drank beer and ate wings!!
Thanks Stalian for the great shipping service and the great stereo!! I am pimping now!!
Matt
Did the same mod with a head unit from a 2003 Supercrew. Swap took all of 2 minutes!
1. Insert removal tools in head unit holes.
2. Pull out old POS cassette head unit.
3. Plug in harness to new unit.
4. Slam it back in the dash.
5. Insert CDs; turn volume WAY up.
Did the swap 2 yrs. ago Used a 6 disc changer from an explore. On my 01 had to trim some plastic away to clear the hight but works fine. So you can use them also if your looking for a unit! Artie
So you can use either the Mach 460 or the Mach 1000 head units for this? Does the 460/1000 represent that watts in the stereo headunit or the total system power it came from? Thanks guys!
I'm not sure if the radios from the mustangs (Mach 460/1000) will work. They have seperate amps in the car so I'm guessing they won't work in a F150.
I took the 6-disc from the '04 Lightning and put it in my '98 Ranger, no problems
I went to a large truck only salvage yard looking for a head unit to put in my 01 but he said the one that matched up was another Lightning. So you guys have said one from the 03 up supercrew would work also. How about the expedition. As many options as I can get would be nice. Or where to find them.
I was going to try and take a ripped out Mach 1000 system off Ebay and put it in the truck, but decided it probably wouldn't be worth it.
Hey guys,
With the 6-disc in dash, do you ever hear a hum or whine (not alternator whine)? Sounds like maybe a fan as it goes away a little while after turning off the deck.
Is there any fix for this?
So 6 disc changer head units from 03< Lightnings, F150s, Expeditions will work?
