Spark Plugs BR7EF - Yet Again.
Old Jul 12, 2004 | 10:18 AM
01-Bolt's Avatar
I am going to remove the blower and intercooler this weekend so I can clean it out and this is a great time time to change the plugs. Right now I am running IT20's and everything seams OK, will find out once I remove the plugs. My question is will it be OK to run the BR7EF's with a 4lb lower? I did a search and it looks likes 12-13psi of boost is on the lower end for the BR7EF's. All my mods are in the sig. Also should I gap them at .038 or .040 since some people have an idle issue with these plugs.
Old Jul 12, 2004 | 10:35 AM
LightninMike's Avatar
i am still running the tr-6's but i think you should be fine
i have heard they are better than the denso's
but that is just me and what i heard
Old Jul 12, 2004 | 11:17 AM
98venom's Avatar
I run the AR-94 which is the same as the BR7EF temp wise without the idle issues.....
MOTORCRAFT
PART# / HEAT RANGE
AWSF-32C / stock heat range - copper plug
AWSF-22C / 1 Heat range colder - copper plug
AWSFA-12C / 2 Hea range cooler - copper plug
AGSF-32C/ Recommended for FRPP heads(not sure on heat range)
NGK
PART# / HEAT RANGE
TR-55/ 3951/ Stock Heat Range
TR-6/ 4177/ 1 Step Colder
BP7EFS (PN - 3526) BR7EF (PN - 3346) two steps
R5724-8 (PN - 7317) two and a half steps
R5724-9 (PN - 7891) three steps
R5724-10 (PN - 7993) four steps
AUTOLITE
PART# / HEAT RANGE
764s / Stock
AR103 / 1 heat range cooler
AR94 / 2 heat range cooler
AR93 / 3 heat range cooler
AR92 / 4 heat range cooler
CHAMPION
PART# / HEAT RANGE
YS-59C / -3 or -4 below stock heat range
DENSO
PART# / HEAT RANGE
IT16 / stock heat
IT20 / -1 heat range
IT22 / -2 heat range
IT24 / -3 heat range
Old Jul 12, 2004 | 11:21 AM
Rob_02Lightning's Avatar
I run Denso IT-22's @ .038 - .040 with 4 or 6 lbs of Extra Pulley, WITH NO PROB's. (3rd Summer on the same plugs)
The 7's should be fine
Old Jul 12, 2004 | 11:48 AM
01-Bolt's Avatar
What is the difference between the BR7EF and BR7EFS in the above list?
Old Jul 12, 2004 | 05:13 PM
echo5oscar's Avatar
I have the BR7's with a 4# in for about 16,000 miles now and have gapped at .035. The idel has always been a little rough but I can live with that.
Old Jul 12, 2004 | 05:41 PM
LightningGuy's Avatar
Do you guys have your tuner account for different brand/range spark plugs when burning you a program?
