front end drop
Old Jul 2, 2004 | 08:44 PM
BLUE N BLOWN's Avatar
front end drop
im attempting to drop my front end this weekend. i have belltech 4804 coils, clunk washers, energy endlinks, energy bumpstops and ford cam bolt kit 4 of each. is there anything i need to know when installing all this?? the clunk washers go on the drivers side only and its the rear lower arm correct?!?!cam bolts does anyone have a link to how to installs these?? is there anything i should do special while installing these also?? thanks!
Old Jul 3, 2004 | 12:42 AM
Ron Rairie's Avatar
I just installed my Belltech 4804's. I still need to have it aligned.
I'm going to install the hangers in the morning.
Belltech claims 1" drop w/ 4804's, Expect 1-3/4" drop.
Old Jul 3, 2004 | 01:18 AM
StruckBy99's Avatar
I got a full 2" with my 4804's. You're correct about the clunk washers. The bolt closest to the drivers door. One goes on the bolt head side and the other goes on the nut side of the drivers side control arm. The cam bolt install is a simple remove and replace. Remember to take out the small factory alignment shim when you remove the factory bolts. Put the new bolts in, in the same orientation as the stock bolts and make sure the round washers sit properly in the alignment guides.
Jason
Old Jul 3, 2004 | 11:40 AM
MaxTorque02's Avatar
Jason
Dang, You running some rubber bands on those wheels?
What profile tire you running? Doesn't look like much support for those wheels.
Old Jul 3, 2004 | 12:30 PM
StruckBy99's Avatar
Yeah......It was a son of a bitch to snap the rubber bands around the wheels. The fronts are 255/35-20's and the rears are 285/30-22's.
Jason
