Attn. Super Ford & Other Ford Tech's
I sent you a couple of e-mails about the Bero sensor?
I'm still getting that code P0106 & P0107???
What would cause this?
Is it just a bad sensor or could something else cause this? This crazy thing is like $140 buck at the dealer.
Do you or any one else know where to get this thing after market?
Thanks,
Suavy
Thanks,
Suavy
my barometric pressure sensor died on me last year about this time. i don't remember what code it threw but i know i did not pay that much for it. i also don't know of anyone that makes and aftermarket unit.
Will
Will
Originally posted by Suavy
spanky, do you remember where you got it changed at? The price I quoted is from a Ford Dealership and it is my whole sale price, I own "Chief Lightning Racing"
Suavy
Suavy
Will
ok guys, here is what I was able to come up with.
If they found me the correct part, ford describes this sensor (as far as the parts department is concerned) as a MAP or Manifold Absolute Pressure sensor. however our trucks don't use a map sensor, they use a Baro sensor. I just mention this in case it helps anybody when dealing with their local parts dept.
anyway, this is the number I came up with:
F8YZ-9F479-CA
my dealership lists it at $164.00 over the counter price.
my employee price is about $75.00
this means that dealer cost is somewhere around $68.00
keep in mind that these prices will vary from dealership to dealership.
another good bit of information to know. the part is also listed under a Motorcraft number. which may increase the chances of you being able to find it locally without having to special order one.
the motorcraft number is CX-1704
hope this helps.
later,
chris
F8YZ-9F479-CA
hope this helps.
later,
chris
Chris, thanks a lot for the info, but what causes this to go bad? Could it be something else tripping this code? I don't want to spend the monney to get this part then still have the fault from something else.
Suavy
Suavy
