nitrous hose??
Old Jun 28, 2004 | 11:55 PM
Built_5.4's Avatar
nitrous hose??
Hi all,
I have a bad end on a nitrous hose, back at the bottle...
Can that end be replaced, or will i need all new hose?
thanks!
Old Jun 29, 2004 | 12:53 AM
MISTERgadget's Avatar
http://aeroquip.com
use the distributor locator to find a location near you. then call and see if they can cut custom lines and fittings, their location near me does it and since they are aeroquip themselves they do a great job.
Old Jun 29, 2004 | 08:47 AM
racetested's Avatar
Make sure as mentioned above that the line is done by a professional. I've seen people just cut the line and use a compression fitting. Not the best for nitrous as you can easily restrict flow with a bad cut and fitting along with a possible leak again.
