Bad Bearing on Caged Pulley!
Old Jun 28, 2004 | 12:25 PM
01Lightning's Avatar
Hopefully this thread will not go to ***** like my last one concerning this pulley...
Anyway, some of you probably saw my last thread concerning a bearing noise. I thought it was coming from my alternator or an idler pulley since the noise was still there after removing my blower belt.
The noise is actually coming from the cage bearing on my pulley assembly!
Has anyone heard of this bearing going bad before?
Well, to my dismay the pulley must come off.
Old Jun 28, 2004 | 12:53 PM
easterisland's Avatar
To clarify maybe you could tell us if the caged pulley is the stock one or if it is an aftermarket caged pulley design and which one.
If you remove it you may as well just install an aftermarket uncaged pulley for ease of maintenance. Or if you choose to keep the caged design make sure to change the accessory belt while you have it off. It is a pain in the neck to remove a caged pulley just to change a belt.
Old Jun 28, 2004 | 01:59 PM
It is a JDM 4# interchangable pulley.
Old Jun 28, 2004 | 05:23 PM
If you want to keep the pulley I'd price the bearing from a local shop and have it done local. Maybe JDM will give you a package deal on a bearing and spindle so check with them also. Probably cheaper and easier in the long run to get a used 4lb uncaged pulley from the classifieds.
Old Jun 28, 2004 | 05:26 PM
JimIII@jdm's Avatar
Former Sponsor
01 I got your email this morning and replyed back that you can send it in to be fixed for free. The spindle may need to be replaced when removed If you need it Ill send it with the pulley when shipping back. The spindle is $65.
JimIII
Old Jun 28, 2004 | 05:37 PM
JimIII
That sounds like a good deal. At least they are going to cover the bearing.
Old Jun 29, 2004 | 08:42 AM
Thanks JimIII for the excellent customer support!
I will be in touch...
Sammy
Old Jun 29, 2004 | 10:03 AM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
...no comment.
Old Jun 29, 2004 | 10:13 AM
JimIII@jdm's Avatar
Former Sponsor
Sammy
Anytime Sammy my pleasure. Sent you a fax with removal instructions earlier today.
JimIII
