2 questions....
Old Jun 26, 2004 | 09:40 PM
birdy111's Avatar
2 questions....
1) Where can I get an SVT plaque/certificate of authenticity?
2) PSP Fast air, Airaid, razors edge cold air w/long carbon fiber tube, JLP box. what do you guys like? what works the best in your opinions? More specifically on the razors edge cai where does the maf go? will my stock 80mm work on that one? all of them?
Old Jun 26, 2004 | 10:34 PM
l-menace's Avatar
Re: 2 questions....
contact SVT, they will send it to you.
2. Yes, they make different models for the 90mm and the 80 mm
Old Jun 26, 2004 | 11:09 PM
EZGZ's Avatar
Who makes a cold air for an 80mm
Old Jun 27, 2004 | 12:57 AM
LatemodelRacer2's Avatar
1-800-FORD-SVT
Old Jun 27, 2004 | 01:36 AM
ILLINI-SVT's Avatar
Re: 2 questions....
1. Calm down. Lightnings are exciting, but there's no need for a coronary.
2. PSP and JLP are excellent, true cold air boxes. Airaid and the K&N FIPK are sufficient, but not as accepted. REM is a nice one (the one I have in fact), but isn't a true cold air intake (no shield to keep hot engine air out).
3. If you just bought a Lightning with a 80mm MAS (99/00 years), you will eventually want to upgrade to a 90mm MAS. So buy an air kit that matches with a 90mm sensor. However, switching to the 90mm sensor requires a new PCM tune, so buy a K&N stock-replacement panel filter for now, and put the new 90mm sensor and the CAI air kit in once you buy a chip (or flash tuner) and program the pcm for it.
4. Welcome!
