Tire swapping question.
Old Jun 26, 2004 | 08:08 PM
FRANKS RED 03's Avatar
I replaced my front tires a month ago due to a blow-out,I kept the one ''good'' tire.Now I have a small hole in my drivers side rear tire.I had someplace patch it yesterday and its still leaking,My question is..Can I place a front passenders side tire on the drivers side but in the rear?I ask in this section becouse i own a lightning and thought someone here could help out.Thanks for any info in advance.
Old Jun 26, 2004 | 09:06 PM
Redlightn 02's Avatar
Hey Frank sorry to hear about your tire problem. I don't think it's a good idea to swap your front right to your left rear, your tires will get messed up and might come apart. Why not use your spare in the meantime until you can get a new tire? I might have an old tire in my garage I could give you, but I can't get it to you until friday at Towers.
Old Jun 26, 2004 | 09:13 PM
Burt,I didnt want to buy two new tires(although i should) but I have the old tire sitting in my garage acting as a door stop,So I was just woundering.Thanks for the offer but if the guy at the tire place doesnt want to swap the tires Im gona just go and buy 2 new ones to go along with the new fronts
Old Jun 26, 2004 | 09:44 PM
BDAZSVT's Avatar
As long as you mount it the correct direction(directional tire) you should be fine. I assume it is not on a rim now?
Old Jun 26, 2004 | 10:05 PM
Frank, give Brian at Wheel World on the Palmetto a call and tell him you know me and that I recomended him , if he has them in stock he should give you a good price under $170 for some F-1's good luck.
Old Jun 26, 2004 | 10:35 PM
AmoJohnny's Avatar
Yea, swapping those tires that are already mounted on rims will not be a good idea obviously. But if you take it to a tire shop and actually switch the tires only, and not the rim, and have the tread facing the right way, ur cool. Its actually good, its like rotating front to back and left to right.
Old Jun 27, 2004 | 09:33 AM
Yeah the tire I have sitting is off the rim,I had it taken off when I replaced the two front tires due to a blow out.I'm hoping the tire shop will slap it on the wheel in the back and tell me its a safe bet.
Old Jun 27, 2004 | 11:55 AM
I just got back from the tire place and they swaped out the tire for me.They said that becouse it was off a wheel already they could put it any were.Thanks for all the help.
Old Jun 27, 2004 | 12:46 PM
Good thing to keep in mind.
