New with a couple of questions...
Old Jun 20, 2004 | 05:57 AM
wjm5806's Avatar
Question New with a couple of questions...
First off I'd like to say Hi to all my fellow L owners. I have a 03 that I purchased new in march of this year. Currently I have about 1800 miles on it. Since it is a weedend toy it rests inside my shop for weeks at a time waiting to be released. While underneath the truck last weekend installing a set of Dynatech long tubes and a Magnaflow catback system I noticed a few drops of oil inbetween the rear of the oil pan and transmission. Is there a possibilty the truck has an oil leak back there? Should I take the truck in for service before any other mods are done? I ask this only because I have several mods that I was going to install before putting the L back on the road. Also after my son and I finished the long tube install I got to thinking about anti seize...was I supposed to put that on the header bolts??? The instructions given with the headers didn't state to do it, only the 02 sensers. Sorry for the long post. I look forward to meeting several of you and seeing your L's in action next weekend at the FFW at richmond! Thanks for listening!
Old Jun 20, 2004 | 09:09 AM
SILVERLIGHTNING's Avatar
If you have to ask, you probably already know the answer.
Old Jun 20, 2004 | 09:22 AM
promodlightning's Avatar
sounds like your rear main seal is leaking. If this is the case it will progressively get worse. As for your LTs, antiseize is recomended but I never have used it for that purpose. I only use antiseize on my plugs.
Old Jun 20, 2004 | 07:51 PM
wjm5806's Avatar
Thumbs up
Well a little update...I pulled the trans out today to install a PT TC and no leak at the rear main seal and I checked the back of the heads and found no drips or leaks!
I'm hoping it was a little leak from sitting on the car lot for so long waiting for to come pick it up. The torque converter install is heck laying on the floor with only a floor jack! I have to restall the trans yet and get those&^%# bolts back in the top of the bell housing. Looking for a trans. jack to help where might I find one that be used with a truck 12" off the floor?
