What's next on the Mod list?
Old Jun 9, 2004 | 11:01 AM
ben_g99's Avatar
Here's a list of mods to date! What should be, could be or do you suggest should be my next mod?
-JDM Flipchip
-JDM #4 pully
-JDM E-Fan
-Cobra R Waterpump
-K&N Filter
-Magnaflow Catback
-Dual Pod A/F and Boost
-Carbon Metallic Pads
-Herbs clunck remover
-Ajustable front cambers
-Lackewoods
Any suggestions? Keep in mind please, that this is my daily driver!
Old Jun 9, 2004 | 11:08 AM
MaxPower's Avatar
Dyno tune. Best $xxx you'll put into it.
Then save up for a MP blower case...or if you're well-off, just buy it now then get the dyno tune
Old Jun 10, 2004 | 10:04 AM
ben_g99's Avatar
MP blower case
Explain! I am not familiar with this ...
Anyone else have some input?
Old Jun 10, 2004 | 11:34 AM
oldfrmtrk's Avatar
FTVB and 170 thermostat…
Old Jun 10, 2004 | 11:54 AM
LTNBOLT's Avatar
Good answer. The stat is a very cheap mod and it doesn't look like he has anything mechanically to help his shift.
Another cheap mod is to dilute your coolant mixtures for the engine and intercooler plus adding Water Wetter. Don't dilute more than you can get away with for freeze protection. In my part of the country a 70 water/30 antifreeze mix is good enough.
Old Jun 10, 2004 | 12:07 PM
ben_g99's Avatar
why is the 170 thermostat such a common mod? Does the little engine temperature change affect performance that much?
Thanks for the reply!
Old Jun 10, 2004 | 02:28 PM
oldfrmtrk's Avatar
Sometimes when you install the 160 it throws an engine light, if you live in cool whether, you system can be stuck on a close loop mode (cold, heat up mode.) I read this somewhere; it uses different fuel tables (uncertain of this.) with the 170 the engine runs a little cooler! Another advantage is that the E-fan will not kick up until the engine reaches 180, if you are moving, the 170 opens and allows fluid circulation, the fluid cools, and it never reaches the 180 temperature to activate the fan… This conserves resources that can be used as “go” power or eliminates strain on the electrical system… IMO
Old Jun 10, 2004 | 04:15 PM
31Charlie's Avatar
I belive he his talking about a Mangnum Powers case.
http://www.teamjdm.com/news/news01.htm
31C
Old Jun 10, 2004 | 06:30 PM
Don's Bolt's Avatar
All good sugestions
Heat exchanger is also a good mod.
Old Jun 12, 2004 | 01:24 PM
BigSVT's Avatar
How bout a ported Eaton from Apton Perf? Or a Accufab TB or boost by pass? The 170 stat and FTVB sound like great mods too
