Please help w/ Lowering Kit
Old Jun 8, 2004 | 10:38 PM
Evil Tim's Avatar
Question Please help w/ Lowering Kit
I called Stylin Concepts to buy a Belltech 3/4. The guy said L's have a lowering kit already and this kit would lower the truck 3/6 because the back has a 2 drop from the factory. Told me to measure for the drop before buying. Is any of this true. Can I just buy the Belltech 3/4. Is it a good kit. Please help
Old Jun 8, 2004 | 10:50 PM
Tim Skelton's Avatar
"belltech" subject line only search results
"bell tech" subject line only search results
If that doesn't do it, try a "search entire posts" search.
Eviler Tim
Old Jun 9, 2004 | 01:19 AM
Ayrton's Avatar
Eviler Tim
Old Jun 9, 2004 | 02:25 AM
DJY1's Avatar
With the Belltech 3/4 Kit a Lightning you will only get a 2/3 drop because the kit was made for a regular F150, Lightnings come stock with a 1 inch drop. The Bell Tech 3/4 Kit is very good, I've had it on my Lightning for 4 years no problems!
djy
Old Jun 9, 2004 | 04:37 AM
AmoJohnny's Avatar
Thats a 2/3 drop???!? Dammn thats LOW. Looks bada$$!!
Old Jun 9, 2004 | 10:32 AM
DJY1's Avatar
AmoJohnny, That is not a 2/3 drop! My Lightning has the Bell Tech 3/4 with Western Chassis 2 inch Lower A-arms.
djy
Old Jun 9, 2004 | 01:43 PM
Konig's Avatar
basically the easiest thing to do is ask for pictures of the different kits installed on actual Lightnings... that way you can be sure you get the look you want.
3/4 drop
Im actually wanting to go down another inch up front to get the "rake" back....but not for a while...too much other stuff to do.
a 3/4 kit levels the truck's body perfectly...the difference in the fenders front to back makes it appear a little higher up front IMO....but no one but me sees it ....well maybe TampaBlack does
Old Jun 9, 2004 | 07:57 PM
DJY1's Avatar
Konig, You are so right about the 3/4 kit looking like the front is higher than the rear and rear always looks like you are carrying a load. That is why I installed the 2 inch lower A-arms.
djy
Old Jun 9, 2004 | 10:24 PM
Dman25's Avatar
Belltech 3/4 drop
Old Jun 10, 2004 | 09:22 AM
Konig's Avatar
djy
So you have a 2" coil and the A-arms then? Your rear almostr looks lower than mine in that pic..but maybe because its black.
Old Jun 10, 2004 | 09:03 PM
DJY1's Avatar
Konig, Are rear ends should look the same I have a 4 inch drop in the rear. I lowered the front with the 2 inch lower A-arms & 3 inch coils to bring the front lower! Because the stance with just the 3/4 looked like was always carry a load! Or maybe, I have 20 inch rims with 45 series tires which fills out my fender wells better.
djy
Old Jun 11, 2004 | 09:57 AM
Konig's Avatar
so Im guessing you only get 1" of actual drop from the A-arms ?
I need to do it...just cant justify the dough when I have so much other stuff going on at the moment.
Old Jun 11, 2004 | 10:37 AM
No! You will get 2" or more. Because the a-arms lower the spring pocket, it does not matter what size springs are in there already.
Old Jun 11, 2004 | 11:12 AM
Konig's Avatar
IC ... that would make sense
You don’t have to be forceful Timmy, sometimes I just don’t think hard enough about my questions before asking ...it’s blatantly obvious to me now
Old Jun 12, 2004 | 07:26 AM
DJY1's Avatar
Konig, so Im guessing you only get 1" of actual drop from the A-arms ?
Yes with the 2 inch lower A-arms I only got another inch!
djy
