somethings wrong need help
Old Jun 9, 2004 | 01:59 AM
WhtSvt's Avatar
i took my L out and as i turned the wheel i heard a clunk i didnt think nothing of it but then as i went down the street i started moving the steering wheel left to right and you could hear something clanging. do i just need to lub up the steering stops or is it something else?
Old Jun 9, 2004 | 01:50 PM
LIGHTNINROD's Avatar
It's probably 'dry' steering stops. Dab some 'heavy' grease on them and listen for the noise again. If that doesn't fix it, you may have a loose lower bolt on the left control arm. You will need special washers to fix that. Do a 'search' on "clunk washers".
Dan
Old Jun 10, 2004 | 10:37 AM
madferraristi's Avatar
Sounds like the infamous "clunk". You probably need a set of Clunk Washers, contact Dave Lynn, $30.00, dplynn1@bellsouth.net
