How much boost?
Old Jun 5, 2004 | 06:18 PM
BuiltL's Avatar
How much boost?
How many pounds of boost should I be seeing with an 8 pound pulley, Ported Eaton, Stage 2 cams, Long tubes???
Zach
Old Jun 5, 2004 | 06:29 PM
StruckBy99's Avatar
You gain boost with the pulley, gain a couple with the ported blower, lose 1 or 2 with the long tubes and lose 1 or 2 with the cams. Should see about 16-18 lbs.
Jason
Old Jun 5, 2004 | 06:41 PM
cpeapea's Avatar
i have a ported blower, ported heads and intake, with cams, and 8lbs of total pulley and i see about 14lbs
Old Jun 5, 2004 | 08:41 PM
BuiltL's Avatar
Yeah I am seeing 13-14 psi max so I think the 16-18psi guess is way off.
Zach
Old Jun 5, 2004 | 08:59 PM
tommylightning's Avatar
With heads, cams, long tubes, 8# lower, 2.75 upper and a ported eaton I was pushing 14#s @ 3,200rpms and then it would start falling off.
Old Jun 6, 2004 | 01:59 AM
StruckBy99's Avatar
Sorry.....my fault. Should have actually totaled what I posted!
8lbs stock plus 8 lb lower plus 1-2 for ported blower minus 1-2 lbs for cams minus 1-2 lbs for long tubes = 13-16 lbs.
Jason
