NO S/C WHINE?
Old May 27, 2004 | 05:03 PM
macracer18's Avatar
Angry NO S/C WHINE?
i don't understand i finally got my intercooler fixed. the intercooler was cloged and the people who put in my motor last year ,put the intercooler hoses on backwards wtf but finally got it fixed but i still have no s/c whine what so ever what could make this happen i still push like 10 pounds of boost and when the intercooler was fixed it took longer to get to 10 psi. any reason it might not work a friend said it could be my exuast i have flowmasters maybe the mufflers guts are blown out its a lot louder then the bassani not deeper but more high pitch louder. i want to get my s/c whine back so any help will be really helpful thanks alot in advance........chris
Old May 27, 2004 | 05:05 PM
blown318's Avatar
Re: NO S/C WHINE?
get a 6lber and a chip...........
that will bring out all the supercharger whine you need!!!!!!!
Old May 27, 2004 | 05:11 PM
macracer18's Avatar
i have a 2 pound upper already but still no noise like there even isn't a s/c i hear my friend justin 01fordlightning he has a 4 pounder and chip and its loud but i have none people ask me if its fake i tell them no just no whine
Old May 27, 2004 | 05:21 PM
770mike's Avatar
do you have the stock air box?
Old May 27, 2004 | 06:15 PM
grinomyte's Avatar
are you getting boost?
Old May 27, 2004 | 06:42 PM
'02silver's Avatar
Maybe your boost actuator needs adjusted.
Old May 27, 2004 | 07:06 PM
Shorty's Avatar
Port that sucker and it will scream.
Old May 27, 2004 | 07:12 PM
cpeapea's Avatar
the i/c got clogged? with what? that may be a reason why it built boost faster, the air backed up in the intake. as far as why its not whinning...im not too sure.
Old May 27, 2004 | 07:44 PM
macracer18's Avatar
i get boost the gauge goes over 10 pounds, and they ford dealer said the intercooler was clogged i don't know how thats just what they said but there was no ehine when the intercooler didn't work and i figured once i got the intercooler to work the whine would come back but i was disappointed and still no whine at all yes i have a stock air box but i should still here the whine atleast a little right?
Old May 27, 2004 | 07:45 PM
wydopnthrtl's Avatar
Got something stuck in your ears? If it's pushing 10psi then you'll hear it. Even with a stock air box.
Rich
Old May 27, 2004 | 07:57 PM
macracer18's Avatar
thats what i thought i just checked the boost actuator and when i turn the key on right before i start the truck it already goes up but my friends don't go up untill the motor is running mine won't even be running and it goes up is this good or bad and how do you adjust it if it needs to be adjusted and how do you tell if you need to adjust it
Old May 27, 2004 | 08:03 PM
'02silver's Avatar
Go here: http://home.midsouth.rr.com/lightningpage/tips.html scroll about 1/2 way down and read the boost actuator adjustment to determine if yours is set correctly.
Old May 27, 2004 | 09:26 PM
macracer18's Avatar
will that make the wine come back or is there any thing else that will make it not wine i think the adjuster is correct
Old May 28, 2004 | 02:47 AM
macracer18's Avatar
ok the boost actuator is i think good any other reason why i wouldn't have a whine
Old May 28, 2004 | 04:14 AM
Red03SVT's Avatar
guys, I've heard his truck. it is truly odd--there really isn't a whine. We even swapped my open filter to his truck and it still didn't really make a whine. there's a little *tiny* bit of whine, but not even 1/4 of what mine stock sound like
-Mike
