What years does the blown spark plug happen??
Originally posted by lx347cid
so all of 03 have the 8 threads?
How about some 02s?
Are these helicoil or are they machined with the 8 threads?
And what exactly are helicoils and whats the difference between them and time-serts?
How about some 02s?
These heads started being produced on or around November 12th (or 18th?) 2002.
so it's certainly possible that a few early L's got the old heads, but reports from at least 1 early build '03 L owner would indicate that this was not the case.
'02 Lightning production was over long before these heads were being produced.
a heli coil is a metal thread insert that is screwed into a larger size aluminum threaded hole. generally used to repair damaged threads, but also used to strengthen threads in aluminum parts. the ford heads are not heli coiled, they are just cast/machined with more threads.
Originally posted by porsen
I assume the plugs are still the same, so did Ford increase the thickness of the block where the plugs are?
Originally posted by superfords
the plugs are still the same.
