weird noise after heavy boosting
Old May 25, 2004 | 12:24 AM
8aSS's Avatar
Unhappy weird noise after heavy boosting
when the truck is raced or boosted up to 14 lbs it makes a weird noise like its releasing some sort of pressure, sort of like a real noisy power steering pump when u turn the wheel all the way in one direction. shortly after the noise goes away and the truck no longer makes the noise
some one local said it could be a bad PCV valve
although it hasnt gottin worse (or better) im still very consurned
anyone had this problem before?
Old May 25, 2004 | 09:21 AM
wydopnthrtl's Avatar
Never heard of that one before. But the PCV is a good place to start.
Rich
Old May 25, 2004 | 09:50 AM
RhinoSlug's Avatar
Could it be belt slippage?
Old May 25, 2004 | 07:18 PM
8aSS's Avatar
is anyone out there who has any ideas?
Old May 25, 2004 | 07:22 PM
Odin's Wrath's Avatar
That's first thing that came to my mind.
Old Jun 3, 2004 | 01:24 AM
8UR LS1's Avatar
i meant after racing not during the heavy boosting
when RPMs come back down to 500-1500 RPM right after the race
sorry about the confusion
help still needed
thank you
Old Jun 3, 2004 | 09:56 AM
teamSLS's Avatar
Hey guys-
if it sounds like a "fog horn" or a "honking" noise, it's probably your IAC.
When you're wide open then shut the throttle, your IAC will kick in to help the truck idle, among other uses.
It seems when these go bad, that's the sound they make and it's during that particular circumstance when it shows (sounds)
Clean it, or replace it...either way, piece of cake fix.
Keep us posted!
-Andy
