Water under pass. side carpet
Old May 22, 2004 | 10:48 AM
TXSVTLIGHTNING's Avatar
Unhappy Water under pass. side carpet
I can see it's dripping from here- (carpet pulled back on pass. side, near tranny hump/firewall area)
I've searched and seen a few people saying to check the drain? Have not see anyone saying where it's at though. No coolant smell either.
Old May 22, 2004 | 10:54 AM
EZGZ's Avatar
Sounds like AC condensate drain if there is no antifreeze.
Does it just happen when you run the AC.
I haven't researched where the drain hose is. Sorry, I think someone mentioned going under the truck but it was hard to find.
Old May 22, 2004 | 11:02 AM
Wookie's Avatar
I had the same problem. Here is a link to another thread that goes over the problem. Link
Joe
Old May 22, 2004 | 11:43 AM
well I took the pass. fender liner out and could barely fit my hand between the head & fire wall to the drain, there is a little plastic cover that I took off and found 2 drains coming through firewall, lower one had water coming out of it, couldn't get it out (not sure if it is suppose to or not). I put it all back together and I guess I'll have to take it by a dealer next week. Oh joy. I came across thise while running cables for my audio stuff.
Last time I took a vehicle in for warranty work, I ended up getting rid of it cause they really took great care of it.
Guess I'll reroute my cables and avoid this area and finish up that job.
