Stupid Question
Old May 8, 2004 | 09:05 PM
RDSVT's Avatar
Question Stupid Question
Will a Navigator 4 valve 5.4 long block work below the stock Lightning intake setup?? Just found one than needs a rebuild because of a rod knock, they pulled and replaced it. Also know where a set of cobra heads are, but that is secret cause I don't want someone to snake them.
Old May 8, 2004 | 09:13 PM
GearHead_1's Avatar
4 valve heads won't work with 2 valve lightning set up.
Old May 8, 2004 | 09:17 PM
RDSVT's Avatar
Is there any differance in deck height between the 4.6 and the 5.4? Mabye could use a cobra lower manifold to. Any one else please chime in
Old May 8, 2004 | 10:50 PM
Sharpshooter's Avatar
Yes the 5.4 has a taller deck, but same size bore.
Old May 9, 2004 | 11:59 AM
Tim Skelton's Avatar
You're really not getting the hang of the search thing, RD.
If you just give it a try, you will be pleased. Just a simple search for "4-valve" and, withing 60 seconds, I was able to bring up everything about 4-valve heads on a Lighting. For example, this is one of the threads returned:
search result
With a good search, you get better information and you get it immediately. The archives here go back to 2002. An unbelieveable amount of information and wisdom.
