blower install question
Old May 7, 2004 | 07:26 PM
lightninquick's Avatar
i got my new blower today
i have done a lot of research
one thing that comes to mind that i overlooked is gaskets
i have a magnum blower and it came with small amount of gasket sealer
i was wondering if it is for the front pulley section or the bottom where it conects to the manifold
Old May 7, 2004 | 07:34 PM
Don's Bolt's Avatar
It is for the snout, so the fluid won't leak ot. You can reuse the stock gasket that goes betwwen the blower and intake.
Drive it easy for the first few miles to break it in.
Old May 7, 2004 | 07:37 PM
thanks for the info
how many miles
thats gonna take a lot of restraint
Old May 7, 2004 | 07:41 PM
potac's Avatar
What pulley combo are you going to run?
Old May 7, 2004 | 07:42 PM
Don's Bolt's Avatar
Originally posted by lightninquick
thanks for the info
how many miles
2-3 miles should be more than enough
Old May 8, 2004 | 01:17 AM
i supose its stock on top
the bottom one i had was a 9 inch pulley i bought it as a 6lb
the one i was told to replace it with is a 4lb and it measures 8 3/4 inches
Old May 8, 2004 | 08:19 AM
Rob_02Lightning's Avatar
thanks for the info
how many miles
Just til the end of your Driveway, THEN NAIL IT
""IF"" your swaping and using your rotors, then I see no reason to break anything in, if you bought it WITH the Rotors, then my guess is go easy for a while, (of course you can get on it a little) make sure all is well, check for leaks, smells, and noises, drive it a little more AND THEN NAIL IT AND STAY NAILED
I'm def getting one of these some day, excellent choice lightninquick, BEST OF LUCK with your new found HP and ET's
WAY TO GO DON, LEAVE THE GUY HANGING.....hehehehehehe
Old May 8, 2004 | 11:06 AM
ShadowBolt's Avatar
Isn't leaving them hanging Don's M.O.?
J/K Don.
Jerry
Old May 8, 2004 | 01:49 PM
thanks 02 lightning
i am useing the stock rotors
don did leave me hanging there but he did help me with the gasket question so i will let him off the hook
Old May 8, 2004 | 02:07 PM
Odin's Wrath's Avatar
i supose its stock on top....
I was told it was a 270 mm. I haven't measured mine, since I don't own a micrometer. It's smaller than stock though.
