Alignment specs
Old May 6, 2004 | 06:03 PM
Fear Itself's Avatar
Alignment specs
If I use the "Owner Preferred" specs:
LH Caster 6.7
RH Caster 7.2
LH Camber -0.5
RH Camber -0.5
LH Toe -0.05 (slight toe in)
RH Toe -0.05 (same)
How will it affect my tire life?
Thanks,
David
By the way, I have a Roush kit and 2" shackle installed.
Old May 6, 2004 | 10:21 PM
SVT_KY's Avatar
The specs you posted are what I ran on my roush kit for years ...
I never had tire wear problems, but that might be cause two new
ones were always going on the front and the old front ones
were rotatetd to the business end of the truck .... Got about 9K
outta each pair that way. ....
Old May 7, 2004 | 12:39 AM
Tim Skelton's Avatar
Those are really conservative specs. Barely any toe and not that much camber either. Don't sweat it.
Old May 7, 2004 | 07:32 AM
Thanks guys, off to the alignment shop.
Old May 7, 2004 | 11:55 AM
Angry
Well, here's a little warning to others with the Roush suspension or lowered front ends. Make sure your alignment shop does not have a drive up (ramp) alignment rack. I got up early to take the L in to a shop highly recommended by a Mac Tool guy I know, only to find out they can't align the truck because it won't clear their ramps.
Anyone know a good alignment shop in Orlando area that does their alignments in a pit?
David
Old May 7, 2004 | 09:23 PM
Originally posted by Fear Itself
Well, here's a little warning to others with the Roush suspension or lowered front ends. Make sure your alignment shop does not have a drive up (ramp) alignment rack. . .
Dunno what kind of rack they had, but my truck is SLAMMED right now -- 2" lower than a Roush -- and I have not only been on an alignment lift, but also on two other lifts.
Maybe the shop you went to just had too short of lead-up ramps.
Old May 7, 2004 | 09:25 PM
SVT_KY's Avatar
most of the "good" shoppes have qa drive on LIFT type
not hte old stationary platform type that was the first
iteration of the laser alignment rack.
Just look for one like that ...
The newest way is generally better ...
Old May 7, 2004 | 11:07 PM
Just to be clear, this is the type that I was talking about.
