Back From the Dyno...I am Sad/Mad
Originally posted by Suavy
Guy's get another tunner! I went from Detroit, Mi to New Jersy to get my first tune. There is more gains to be had by going to JLP, JDM, PSP, Razors Edge!
Just my 2 cents!
Just my 2 cents!
I been trying to get a hold of the tuners but no luck.
What's up with JL? I can't get inside there website or anything. There number don't work or I am calling the wrong.
Tried PSP but no luck also just the machine. Left a message though.
hmm
395 / 489 area if i remember right
With a 6lb lower and a ported eaton, i'm guessing you should be in the 44x hp 52x ftlb area.
Here is my dyno sheet
First run was with a 5 lb pulley tune
----- a/f thingy was shot out from my exhaust at almost end of the run-----
Second was with a 6 lb pulley tune
Didn't keep running it becuase the guy didn't know exactly was need to make my truck run better.
During third run rwhp went down to 368.
Just my 2 cents!
Just my 2 cents!
SLIPPAGE!!! Some blowers just dont like the 2.8 upper combo, I ran a ported blower truck with a 2.8 upper and a 6# lower and was only hitting 13psi. I switched it out for factory upper and 6# lower and we are now seeing 15#'s. first dyno was 440, last program hit 458, more gains to come with more tuning, now... to try that 8#er on the stock bottom or not
Just my 2 cents!
Just my 2 cents!
here's my Apten port job, before and after w/ a JDM tune
My chip is on it way to JLP. Hope everything is corrected and I finally get my truck running as it should. Will post dyno sheet as soon as I get my chip back.
I sent it next day air,,,, it sucks I had to drive my truck for more 50 miles without a chip. It like poeple know when to dare you to race them and you can't .....
I will have to hunt them down next week if all goes right.
I got my JLP tune this week and finally I put it in and I was off to the dyno.
Still not happy with my numbers.
401.52 rwhp and 465.84 torque
A/F ratio was in the 12.4/1 range
Run conditions were 93.44 ' F, 29.87 in-Hg, STD: 1.04
Can the weather condition drop my numbers this much or should I send it back for more tweeking?
I will hit the track tommorow to see how it runs.
