New 03, couple of problems.
Hey guys,
I traded the 01 in for a left over 03 with 15 miles on it and I got a smoken deal! Got a couple of problems with her though.
First, the tires seem to be out of balance. I brought it to the dealership and they can feel the vibration at 60 mph but said the tires are fine. Theyre going to take the drive train out and bring it somewhere to make sure its balanced. This seems like overkill to me. Im thinking it might be something related to the truck sitting on the lot for over a year.
Second, Im getting a humming noise from the radio. Sounds like engine noise. When I turn the volume down, you can hear it extremely clear. After you turn the radio off, the noise stops about 2 seconds after. When you turn the radio back on the noise returns until you turn the radio off again.
Just wondering if theses are common problems or not. I also need to install the drop shackles but Im waiting for the vibration to get fixed.
Thanks,
Scott
Thanks,
Scott
Re: New 03, couple of problems.
like you said, it's probably just flat spotted the tires after sitting on the lot for over a year.
good luck.
BTW, do they have a modern tire balancer?
did they do a "road force" balance?
just curious.
later,
chris
I know! I'm sure they do have a modern tire balancer...they're a big dealership and have the "presidential" award. Not sure about the "road force" balance, but they said everything is balanced and that's the only think left to do...
Thanks,
Scott
Thanks,
Scott
Regardless, thats what it is. Good luck with your vibration
my stock tires were out of balance too...if the dealer cant get it...go to a high end rim shop who uses the glued weights on the inside of the rim. they will work much better than the clip ons, when mine wee slashed and i replaced them with nittos i had the same balance done again and no shaking yet...not even at 140 mph
Originally posted by Almightywad
Is that the sorta high pitched noise I keep hearing in the background? I was wondering what that was.
A.) Get a different head unit
... B.) Turn the volume up louder
...C.) Get a some long tube headers and drown it out with the exhaust
The radio is a common complaint here. Ford knows the fix.
Most likely tire noise. Balanced tires can make noise. SVT vehicles sit for months because they don't let everyone drive them. They get flat spots as mentioned. Mine made noise until I took a long road trip, then they shut up.
Like the rest said it's the fan in the radio. Had mine replaced. It's much better but still will come on although much quieter at mid volume. And yeah the drive is not likely out. I would get new tires or if they won't do that at least get them shaved.
Re: Re: New 03, couple of problems.
I couldn't have said WTF better myself
Coug
If the thought of a Dealership messing with your Motor, Tranny, and or Rear doesn't scare you -->IT SHOULD <--
GOOD LUCK BRO, AND CONGRATS........
Originally posted by superfords
they are gonna do WHAT?
chris
chris
Coug
Originally posted by Sharpshooter
Mine too. It sat on the lot for 6 months, so the dealer ordered me a new set and all was good.
