- QUICK Shock Install Question... -
Old Apr 19, 2004 | 03:53 PM
Krix330cic(NJ)'s Avatar
Arrow - QUICK Shock Install Question... -
Once shock is installed, there is the rubber washer & nut (isolator nut?) that goes at the top...
QUESTION how tight do i make this?
I have the jack under the control arm, jacked until the shock cant go up anymore.... do i just spin the rubber washer/nut all the way down snug, then remove jack?
Old Apr 19, 2004 | 04:40 PM
Hilander's Avatar
If it's the rubber washer, I just tightend mine till the rubber bushing spread out a little.
Old Apr 19, 2004 | 05:24 PM
max mitchell's Avatar
As you tighten, watch the UPPER and LOWER bushings up top. They'll snug up, then slightly start to equally bulge; stop there. Don't crank them down and swell them outside the washer/keeper.
Old Apr 19, 2004 | 05:30 PM
worked out perfect, thanks.
