Transmission Leak during burnout
Old Apr 19, 2004 | 12:44 AM
shawnting's Avatar
Went to the track this past weekend and the XMSN was leaking (not dripping) after the burnout. Cooled it down and no leak, drove it around and no leak, power brake it again and leaks. What do you all think?
My current mods to the XMSN is just an aftermarket valve body.
Old Apr 19, 2004 | 07:42 AM
EZGZ's Avatar
Need more info. Please
Did you overfill it after replacing valve body?
Does it shift allright?
Where is leaking from?
Old Apr 19, 2004 | 11:10 AM
Tim Skelton's Avatar
Mine puked from the vent once after hard track (road race) use. Ford reps at the track said don't worry about it. Some road racers recommend removing 1 quart before racing.
Old Apr 19, 2004 | 12:21 PM
LIGHTNINROD's Avatar
As other's have said....."overfilled"
Dan
Old Apr 19, 2004 | 04:36 PM
shawnting's Avatar
It's shifting properly and leaking from the bottom (not from the pan). Overfilling sounds right, but why didn't it leak on the first run and only when I power break it?
Old Apr 19, 2004 | 04:47 PM
Sandman_A_C's Avatar
Are you sure its coming from the transmission???? It could be coming from your power steering resevior....
Old Apr 19, 2004 | 10:38 PM
Factory_Tech's Avatar
You may have heated up your front seal at the pump and it's leaking like a sieve, this is pretty common when you do long burnouts (anything over 30-60 seconds is pretty darn hard on the pump, I wouldn't) When it cools down the seal holds it better, but it's only gonna get worse, look inside the dust cover and see if there is fluid inside the bell, if there is, you need to get that seal replaced.
Hope this helps,
G
Old Apr 20, 2004 | 01:29 AM
shawnting's Avatar
Factory_Tech,
What can I expect this seal job to cost me?
