I was told not to gap my plugs
Old Apr 16, 2004 | 11:16 PM
jred's Avatar
I was just told by a vendor that i should not change the gap on my plugs (denso it22) that denso reccomends not touching them. This is contrary to everything that i have read here
Old Apr 16, 2004 | 11:24 PM
Thor01's Avatar
Re: I was told not to gap my plugs
#1 Rule with plugs. Always inspect the plug and verify the gap is set correctly. I don't care what Denso says. I have pulled new plugs from cars that had no gap and were installed in engine build.
A few minutes will save you a hassel later.
Old Apr 16, 2004 | 11:41 PM
jred's Avatar
That is what i thought which is why i was confused. I was planning in gapping them at .38-.40 for a 4lb as per everything that i have read on this and other forums
Old Apr 16, 2004 | 11:44 PM
Robert Francis's Avatar
I've got Denso's IT-22's - and checked and re-gapped every one of them for my application. Perhaps the gap "in the box" is ok for stocker, but obviously Denso couldn't know specifically what "you're" using them for. And under any circumstances, as previously noted: you have to check the gaps to be sure what you've got.
Old Apr 17, 2004 | 03:45 AM
Rob_02Lightning's Avatar
And when I checked AND HAD TO GAP MY IT-22's
They were no where near .038 -.040 (I run that gap also)
