Where to tap for mechanical boost gauge?
Old Apr 13, 2004 | 11:07 AM
ben_g99's Avatar
My stock gauge (I hope it's inacurate) shows 10 psi with just a filter.
How accurate is the stock gauge?
Now I would like to install a mechanical boost gauge in yhe truck. Does anyone have a install page online? Where do you tap in. I already have the gauge, hose, and T-fitting, I am just waiting on the pod.
Thanks everyone!
Old Apr 13, 2004 | 11:49 AM
secstang03's Avatar
I tapped in right under the dash on the drivers side. If you look under the dash, you will see the existing line. There is also a fitting about in the middle. I pulled out the fitting, replaced it with a tee and installed the new boost line.
I can get you pics if you need.
Old Apr 13, 2004 | 12:09 PM
tallimeca's Avatar
stock line
you can use the stock line, but i wouldn't tee it. Just disconnect the stock guage and connect up your new one. The mechanical guages aren't the most accurate and i've found feeding vac/boost to both guages, then to just the new guage shows different settings. I have an autometer mechanical vac/boost gauage so i have no use for the stock guage....which will probably end up breaking at some point anyhow.
Just my opinion.......
Old Apr 13, 2004 | 12:30 PM
ben_g99's Avatar
I you have pics available I would love to see them. It would get me a much better idea at what I am looking for.
Ah, ok. I honestly did not know that the stock gauge is mechanical. I thought it was a electrical gauge.
Do I have to remove the gauge cluster in order to disconnect the stock line? Is this hard to do.
Old Apr 13, 2004 | 07:47 PM
denny0328's Avatar
look here, the install shows some pics...
http://www.timskelton.com/lightning/.../gauge_pod.htm
it's about 1/3 of the way down..
-dennis
Old Apr 13, 2004 | 10:08 PM
Still Smiling's Avatar
Great instructions and pictures to go along.
I, however, would not use a T-tap for the connection of the gauge lights. You would be better off soldering the wire and taping or shrink wrapping.
Old Apr 14, 2004 | 12:03 AM
ben_g99's Avatar
-dennis
You da Man!
