I Am A ..........moron
Old Apr 13, 2004 | 01:02 PM
superfords's Avatar
I'm not sure how your fuel solenoid feed line is setup, but if it goes in at the schrader valve fitting, then it is pipe thread if I 'm not mistaken. you shouldn't be trying to put a bolt in there! but I guess you already figured that out.
good luck.
later,
chris
Old Apr 13, 2004 | 02:02 PM
Green_98's Avatar
my dumbazz broke the plastic petco-ck off into the raidiator when i was tightening it up with a cresent wrench after a flush
Old Apr 13, 2004 | 02:36 PM
temp1's Avatar
Im a big plumbing moron. For some reason I forget that some water can remain in the pipes when I sweat the pipes to break them apart and I pull them apart and hot steam/water comes out. I have scalded myself a few times this way.
Old Apr 13, 2004 | 03:28 PM
TampaBlack99's Avatar
I am pretty good with tools, it's knifes I need to stay away from.... cut the same finger off twice
The good thing is when it's gonna rain my finger starts to ache, it's like my own little weather man.
Old Apr 13, 2004 | 06:57 PM
WideOpen03SVT's Avatar
HEY TAMPA......LMFAO!!!!! LOL!!!! THINK I PISSED MYSELF!!!!
Old Apr 13, 2004 | 08:10 PM
blown318's Avatar
Old Apr 13, 2004 | 10:11 PM
ND4SPD's Avatar
good luck.
later,
chris
see I know it should have a shrader valve there but there isn't one...pic below of what was there, it should make sense now. Male thread to go in rail and has an AN female for the hose to connect too. OH, it is barely leaking..like a tiny bit, would it be ok to put some JB weld on it to tide me over untill I can get the rail out of there to use an EZ out to get the bolt out. Does anyone have any good instructions to remove the passenger fuel rail. Do I have to remove both side to get it off, from what it looks like I do. Any tips would help out. Thanks
Old Apr 13, 2004 | 11:38 PM
TriPodRacing's Avatar
The schrader valve is removed when installing nitrous kits.
Old Apr 14, 2004 | 12:42 AM
SlammedSVT's Avatar
Originally posted by LatemodelRacer2
You know what happened dont you, this is a sign from GOD saying leave the nitrous on there or something
Thats one way of looking at it.
