Drum Roll: Compression test results!!
Old Apr 12, 2004 | 03:27 PM
halflife's Avatar
Cool Drum Roll: Compression test results!!
The results are in:
1 trip to the emergency room
5 stiches on my pinky knuckle
5 PSI of pressure in Cyclinder #8!!!!!!!!!!!!!
Piston anyone?
Old Apr 12, 2004 | 03:37 PM
yysenhimer's Avatar
That sucks.
what did you do to your pinky knuckle?
...and for the record, I've done compression tests on fuelie motors with and without the throttle plate tied wide open and got consistent results either way.
Old Apr 12, 2004 | 03:46 PM
grinomyte's Avatar
nice, nothing like suffering major injury while working, i love that.
well while you need to have the pistons takin out. . . .might as well . . . build your lower end huh? But at least your found your problem. Also did you throw some fresh oil in there and see if it went up?
Old Apr 12, 2004 | 03:58 PM
halflife's Avatar
I slipped taking out the first spark plug, so that ended that test. I had to put the plug back in and Drove myself to the E room with my hand gushing blood and my truck shaking all over the place.
I did not do the oil test because I wanted to make sure I do it right. Do I just pour some down the spark plug hole? How much oil do I need to put in there?
Old Apr 12, 2004 | 04:01 PM
grinomyte's Avatar
i think an oz or so.
Old Apr 13, 2004 | 12:16 AM
LTNGFAST99's Avatar
*gulp*
sorry tom.
Old Apr 13, 2004 | 01:25 AM
ND4SPD's Avatar
Man that sucks...we all make mistakes though, I know I do.
Old Apr 13, 2004 | 06:11 AM
Fast Gator's Avatar
Atleast you didn't get something in your eye
Old Apr 13, 2004 | 06:35 AM
D Davis's Avatar
thanks Gator I needed a laugh this morn.
halflife, that BITES, about the truck. at least the finger will heal itself . And you could still see to drive to ER
Old Apr 13, 2004 | 06:37 AM
Rob_02Lightning's Avatar
Gee I wonder who Gators talking about
So I couldn't see for a week, BIG DEAL
I took the proper precautions to warn people on the road
That sucks halflife, VERY sorry to hear it
Maybe it's a cracked busted bend or burnt Valve
I rather have that than a hole in the piston ?
I guess the next move is to remove the head, BUMMER
I hope you figure it out and get it fixed fast
THIS SUCKS *@$#(!@#$(!@#)!@##@
Old Apr 13, 2004 | 08:21 AM
EZGZ's Avatar
Two or three squirts with your basic trigger style oiler.
Sorry about your hand. Two bad you can't just pop a couple pain pills in the gas tank and wait for these trucks to heal themselves.
Just for giggles try it with your throttle open and closed back to back testing.
I usually count off 6 or 7 cycles when I crank it.
Good Luck
Old Apr 13, 2004 | 09:30 AM
jimkalfakis's Avatar
Wan`t a real cheap fix? Just ALOT more boost. That should build up some compression. HEHE
Sorry Tom, just joking.
Old Apr 13, 2004 | 12:39 PM
superfords's Avatar
if you really only have 5psi of compression, then a few drops of oil sure isn't gonna change anything...
put shop air on it and see where it comes out (crankcase or intake/exhaust.
good luck
later,
chris
