nitrous 101?
Old Apr 13, 2004 | 11:45 AM
snoop's Avatar
nitrous 101?
I know alot of you are running nitrous so I have a couple questions. (I have a 4# lower pully)
- How mony shots can I use safely?
- Is it best to use a wet or dry kit?
Old Apr 13, 2004 | 12:12 PM
Rob_02Lightning's Avatar
Be prepaired to hear a million diff opinions
"BUT"
Quick and simple answer
YOU DEF WANT WET when using Nitrous on a Turbo or S/C Motor.
4lb + 50-75 HP is fine and actually quite safe "IF" you have a nice RICH TUNE, COLD PLUGS, AND PROPER TUNING AND TIMING.
I run as aggressive as 6lbs + 75 HP but I would NOT recommend it
Old Apr 13, 2004 | 12:53 PM
wydopnthrtl's Avatar
I'm with Rob. get the proper tune (added fuel + pulled timing) and your good to go with a "wet" system.
Rich
