gregg evans i need help!
Old Apr 5, 2004 | 05:05 PM
Jubelands's Avatar
FTVB help!
well i installed my 2cr ftvb today and it is waaaaay too insane. My truck is basically stock and i used to have the regular version of the ftvb but felt that it was too mild.
I cant even go WOT, when i do there is a loud clank coming from the rear when it shifts, it sound like the driveshaft. Is there any way you can make a custom version of the valve body, something in between the 2c and the 2cr?? Help
Old Apr 5, 2004 | 06:26 PM
jgstang67's Avatar
Jubelands,,
I have found the vb's seem to "calm down" a little after a 100 miles or so, I THINK it takes a while for all the worm trails in the VB to bleed any air. At least that has been my experience with them..... One question ... do you have any type of traction assist device? I hope all ends as you wish!
Old Apr 5, 2004 | 10:44 PM
Jubelands's Avatar
well the valve body has calmed down a little so it's cool now. The only problem is that my leaf springs are binding and slamming into my frame everytime it shifts. What can i do to stop the springs from binding. Can't really afford traction bars at the moment. Would leaf spring clamps help??
Old Apr 6, 2004 | 02:17 AM
Factory_Tech's Avatar
Well, the 2CR will hit pretty hard, but I responded to your e-mail so shoot me an address and I'll get you something a bit in between to try out.
G
Old Apr 6, 2004 | 02:22 PM
Blown347Hatch's Avatar
Unhappy Newbie stupid question
Does the valve (or valve body) trans warranty? I'm assuming the answer is a resounding YES?
Old Apr 6, 2004 | 10:08 PM
Jubelands's Avatar
Not exactly sure? I'm sure greg would know though.
Old Apr 6, 2004 | 10:21 PM
l-menace's Avatar
JUDELANDS
do you have traction bars?
it might be your rear end twisting during the 1-2 shift.
If you have slapper bars (lakewoods or truck tracks) they may need to be set closer to the frame
Old Apr 6, 2004 | 10:27 PM
AMP's Avatar
AMP
Originally posted by jgstang67
Jubelands,,
I think mine calmed down immediately after coming down off of the lift, or maybe the worm trails are actually full of worms, or maybe I just bought the wrong color?!
Old Apr 6, 2004 | 11:25 PM
wkuper11's Avatar
wait, there are 2 versions of the FTVB? where have I been and who has the new version?
Old Apr 7, 2004 | 01:31 AM
Jubelands's Avatar
Originally posted by l-menace
JUDELANDS
Actually i dont currently have any type of traction device. I found out that the clanking sound was coming from the leaf springs binding up and slamming into my frame. I have nitto drag radials on the truck and they dont spin on the shift, they stick and bounce which cause the bindingand clanking.
I checked under the truck and the frame where the leafs were hitting is banged up pretty good. it's happening on both sides but a lot more on the drivers side than the passengers.
What could i do?
Old Apr 7, 2004 | 02:47 AM
SICKBOY's Avatar
buy slappers
100 bux...plus they will help those nitto's hook even better
