Need some Advice!
Old Apr 6, 2004 | 12:27 AM
AMP's Avatar
AMP
Originally posted by ND4SPD
just a thought but have you tried removing the chip and see what happens.
not sure if you're responding to me or slammedsvt, but I'll chime in. I'm using a Predator now, in place of my diablo chip. This never happened with my chip, but seems to happen quite frequently since I started using custom files for the Predator.
Grinomyte-I haven't checked the IAC yet. Is it worth just replacing it? any idea what a new one costs?
Old Apr 6, 2004 | 12:39 AM
LTNBOLT's Avatar
If you flipped it to the aggressive side of the chip in cool weather without higher octane fuel mixed in then you might have melted a tip or two on your new plugs. Did you hear any detonation?
It will still run with a little miss if the plug is not damaged too bad.
Old Apr 6, 2004 | 01:02 AM
grinomyte's Avatar
iacs are notorious for going back on fords, so even if you don't need it now, chances are down the road you will, but either case, you can still return it if it doesnt fix your problem. They run about 60-70 bucks.
Old Apr 6, 2004 | 01:06 AM
AMP's Avatar
AMP
thanks
Old Apr 6, 2004 | 01:15 AM
speeder's Avatar
Try cleaning the MAF sensor with some contact cleaner, if you have a K&N filter the MAF can catch some of the oil from the filter, also try cleaning your idle air control valve, they can get dirty and stop working properly, I clean mine with carb cleaner every month and a half or so.
Old Apr 6, 2004 | 10:06 AM
SlammedSVT's Avatar
The first time I flipped the chip was when it was about 76 degrees outside. I have never flip it in cold weather or below 65.
I havent cleaned my maf or checked my aic yet either.
I will try that and post back.
Old Apr 6, 2004 | 10:55 PM
SlammedSVT's Avatar
Cleanned my maf. I havent checked the aic yet. This weekend I am going to check my plugs.
This might be a stupid questions, but how do you check to see if the coils are bad.
Old Apr 6, 2004 | 10:59 PM
grinomyte's Avatar
normally it'll throw a misfire code and you move it around. I've also heard that bad coils are really hot to the touch but aside from that i don't know how else you can test them. Sorry.
Old Apr 6, 2004 | 11:07 PM
SlammedSVT's Avatar
I dont know how I could check to see if was hot because I dont want to take the plugs out when she is hot.
It might be easier just to go to ford and hook it up to a machine.
How much does that usally run?
Old Apr 6, 2004 | 11:19 PM
grinomyte's Avatar
dunno, but not the plug, the actual coil will be hot. I don't know exactly how true this is because i've never experienced it first hand, just hearsay. You can touch the coils tho, no problem. Maybe you should use one of those infrared temp sensors, but a burn is worth it if your gonna find your problem.
Old Apr 6, 2004 | 11:32 PM
SlammedSVT's Avatar
Sorry about that. I miss understood you. Ok I will check the coil then. I hate burns but your right about that one.
Thanks for all you help btw grinomyte.
Old Apr 6, 2004 | 11:34 PM
grinomyte's Avatar
