"Low Fuel"
Old Mar 25, 2004 | 11:50 PM
USMCJon's Avatar
"Low Fuel"
Hey about how many miles will a Lightning get after the "Low Fuel" light has come one.
Lets just say i'm in one of those situations where all the gas stations are closed and I need to be somewhere tommorow before they open.
Thanks,
Jon
Old Mar 25, 2004 | 11:54 PM
Tim Skelton's Avatar
Like forever. I heard that there is two gallons or more left, but guages are notoriously unreliable, so yours might be 1/2 gallon. How many gallons do you use to fill up when the light is on?
Old Mar 25, 2004 | 11:56 PM
JimJr's Avatar
when my light comes on.....i have exactly 3 gallons left till completely empty. so its about 30 miles
SlammedSVT's Avatar
Re: "Low Fuel"
Thanks,
Jon
I think it usally comes on with around 3 gallons in the tank, so what ever milage you usally get per gallon I guess.
Old Mar 25, 2004 | 11:58 PM
USMCJon's Avatar
Thanks I appriciate the input. I should be able to swing it tommorow.
Old Mar 25, 2004 | 11:59 PM
Sandman_A_C's Avatar
I would like to know the answer to this too.
I've put 5 tanks thru the truck so far and it breaks down like this:
50 miles it comes off the F
150 mile I'm at 1/2 of a tank.
I have always filled up when it got down to 1/4... It drinks the gas so fast I'm afraid not to. But when I do fill up, I have between 6-9 gallons left in there! I run about 225-250 miles before I fill up.
Old Mar 26, 2004 | 02:18 AM
hslightnin's Avatar
dam that sux
Old Mar 26, 2004 | 03:10 AM
Dman25's Avatar
ok well, if im on the freeway my gauge wont even move off the F until about 60 or 70 miles, half way im at 200, and the light comes on at about 300 with about 4-5 gallons left.
Old Mar 26, 2004 | 07:50 AM
litnfast's Avatar
I let my tank get as low as it has ever been this past week. I kept looking for that little gas pump light to light up but it never did. When I filled up it took 21 gallons.
Old Mar 26, 2004 | 09:09 AM
tallimeca's Avatar
low fuel
I think Vinnie actually tested this once and said about 35-40 miles.
My light usually comes on on the way back from the track
Old Mar 26, 2004 | 10:23 AM
DHFerguson's Avatar
Mine takes 22.5 gallons when the light comes on. I put 24.9 gallons in once after running 40 miles (carefully) after it came on.
This is fun: Hold your trip/odo button in while you start the engine, then keep holding it in a few seconds until you see 'TEST' on the odometer. Then punch the button several times and it will toggle through a systems test, RPMs, MPH, etc. until you get to FUEL. You'll have a digital reading of the fuel level. I think mine reads ~280 when full and ~45 when the light comes on.
Old Mar 26, 2004 | 10:29 AM
clonetek's Avatar
When my truck is on "E", I can put in 20 gallons of gas.. And since we have 25 gallon tanks, i always thought we had 5 gallons left after "E".
Old Mar 26, 2004 | 10:36 AM
MEAT BAG's Avatar
When my low fuel light comes on i can still put 20 gal of gas in it.
Old Mar 26, 2004 | 10:50 AM
wydopnthrtl's Avatar
Mine comes on with about 3.5 to 4 gallons left.
Rich
Old Mar 26, 2004 | 12:07 PM
Konig's Avatar
Rich
bingo, I have pulled over exactly when the light comes on to test it out. The 3 times I have done it I had bout 3.5 - 4 left in the tank
