E-Fan Wiring Guru's ?
Old Mar 20, 2004 | 07:19 PM
Twisted99's Avatar
Will this thermal sensor\switch work with
a 30 amp relay. Should I jusr wire one side to the relay and one side to ground....I have a used JDM E-Fan and don't have the sensor for this kit..If I tie one end of this sensor in the link to the JDM sensor wire and the other to ground would this serve the same purpose?
http://www.jegs.com/cgi-bin/ncommerc...11&prmenbr=361
Old Mar 20, 2004 | 08:04 PM
Don's Bolt's Avatar
Do you have the wire harness that came with the E Fan, and is it the dual relay setup?? If so I would call Justin and ask him to send you a sensor that comes with the kit.
If not call him and ask him for a wiring harness kit for the fan.
You don't want to be messing with your cooling system, do it right and keep your truck safe.
Old Mar 20, 2004 | 09:40 PM
Twisted99's Avatar
Yes I have the dual relay setup...and the 40 amp breaker for the toggle on off...
I can run it in with the AC on till I sort this out....Cools fine this way..round 184 degrees....
