which are the best traction bars?
Originally posted by SVT-SiNiSTER
How well will i hook with some metcos and street tires?? Do they really help
So, if you are not getting wheel hop, traction bars are not going to help you one bit.
But I consider them mandatory in any high-HP vehicle with leaf springs. Driveshafts can and will break without them.
Before modding I had no wheel hops. After modding which boosted my HP & TQ I started to get wheel hops. So I had a pair of Metco Upper Track Links installed to cure the hopping issue which causes bad traction and can snap your driveshaft.
Metco traction bars will "help" with traction, you can set the preload.
It's not a world of difference with street tires, but with DR's you can easily tell the difference. This is with stock output.
If you have regular mods like 4#, chip, filter, the only real alternative for traction is traction bars/slicks.
T-Bars
I've been using JDM's Rancho style bars for 3 years now and I think they do a great job. I'm sure JLP's and LFP's are just as good. The design not only stops axle wrap but also helps lift the weight from the front of the vehicle towards the back where it is needed, John H.
