Help,E-Fan & Metco Tensioner & Stock H2O Pump???
Old Mar 20, 2004 | 01:57 PM
Twisted99's Avatar
So it's looking like I can not use the E-Fan with the Metco tensioner setup and retain the stock water pump...AM I wrong? If not were can I find a water pump that is compatible ..I need one today..so I'm looking for a performance pump with no snout for the clutch fan . Will a regular Mustang pump work....please advise..
Old Mar 20, 2004 | 03:32 PM
Struck in AZ's Avatar
Last I checked the Metco tensioner was no where near the water pump or the stock fan. You should be able to use it without any issues at all...what problems are you having?
Old Mar 20, 2004 | 10:52 PM
Robert Francis's Avatar
I put on the Metco Idler setup before I installed an E-Fan on my 01L. My Metco Idler isn't anywhere near the water pump. Later on I installed an E-Fan from LFP and changed water too - didn't touch my Metco setup.
