Q for Rob02?
Old Mar 17, 2004 | 03:42 PM
bad00's Avatar
Question Q for Rob02?
Rob do you run a plate on your truck? If so witch one and what did you need to hook it up to the zex system?
Old Mar 17, 2004 | 06:26 PM
Blown5Pnt4's Avatar
I believe he uses the PSP plate
Josh
Old Mar 17, 2004 | 07:50 PM
Rob_02Lightning's Avatar
Yes, I'm a PSP Plate user, and I love it.
Sal designed an awesome product with that Plate,
easy as schitt to set up, easy enough to get to when changing jets. It's flowed flawlessly for me thus far.
I'm using a Wet Nozzle, if you notice it also has a tapping on the other end, that's used for a Dry Nozzle (obviously 1 gets plugged)
It comes with all the needed gaskets and hardware
It's a breeze to put on
Old Mar 17, 2004 | 07:52 PM
You can adjust the jet at any angle (Ya I know schitt pic)
This is the view looking through the Throttle Body at the back of
the nozzle
Old Mar 17, 2004 | 07:56 PM
Under view once the lines are hooked up
(dont mind the wires, I was in the mid of something)
Last, a close up from underneath
YOU NEED NOTHING TO HOOK IT UP TO ANY SYSTEM
All you need is your nozzle
Hope that helped Bad00...........
my entire Nitrous install is in my Mod Gallery (clic sig pic)
Old Mar 17, 2004 | 10:36 PM
bad00's Avatar
Thanks Rob, looks sweet I'm gonna need to order a plate soon. I already have the nozzle in the rubber boot, so I guess I have to plug the hole in the boot when I get the plate.... Man I shoulda just went with the plate from the begining.....
Old Mar 18, 2004 | 02:10 AM
shawnting's Avatar
bad00,
Or you can purchase and polish the C&L tube for $110 on Ebay.
