Got predator today..HELP!!!!!!!
Old Mar 13, 2004 | 05:50 PM
red99svt's Avatar
Ok i got the predator today and installed there performance pulley tune.Jumped in the truck and started to take her for a test drive when i heard my baby pinging like crazy so i pulled over and used the pulley/performance 90mm tune it says its for 99-00 lightning's only.Well i thought a 99 had the 80MM MAF. Well i drove home and this tune isnt making the truck ping.I also went and mnodified the tuen as well by adjusting the timing a hair advance and also riched it up alittle bit. Oh and also firmed up the 1st to 2nd shift alittle. What have u exsperienced predator guys found out works the best. Check out my mods and tell me what tunes or modified paramaters i should use.THanks guys
Old Mar 13, 2004 | 06:24 PM
EZGZ's Avatar
What list of MODS?
All I saw in your profile was you had a 99?
You did mention a pulley? What size?
Old Mar 13, 2004 | 07:19 PM
red99svt's Avatar
OOPS sorry my sig isnt showing up with my list of mods..So here ya go.,.
99´ Red Lightning
Mods- 3/5 drop, Airaid CAI,4# lower pulley, Billet grille,Smoked taillights,
02' L Wheels,Tonneau cover,JDM catback,2 gauge pillar pod, Autometer Lunar gauges,Predator..
Times-13.4@103 60'@2.0 lol
Mods 2 come-Nitto DR's,drive shaft loop,Gauge pod,2#upper,FTVB,
Old Mar 13, 2004 | 07:38 PM
EZGZ's Avatar
Like I said, I still don't see no engine mods.
Just that upper pulley.
The 1st-2nd shift was a good idea.
I would stick with the mildest tune and run good gas until your ready to up the anti.
Don't forget to keep that fuel filter clean.
Cold air kit next on the list.
Old Mar 13, 2004 | 07:41 PM
red99svt's Avatar
DO u think its a bad idea to run that pulley/90MM tune it ways its for the 99-00 lightnings but they came stock with a 80MM MAf...
Old Mar 13, 2004 | 07:50 PM
EZGZ's Avatar
oooops
missed that 4# lower. Thats a little more serious. hmmmmm
I better crawl back in my hole. hehehe
Old Mar 13, 2004 | 10:53 PM
LightStruck's Avatar
Not sure if this is exactly what you're asking...but I was once told by a tuner if you run the program that is for a 90mm MAF and you actually have a 80mm...it is no problem, you'll just run a little richer because there's not as much air coming in as the computer thinks---(safer). If it were the other way around, w/ 80mm program and actually running a 90mm MAF, you would be running leaner.
Old Mar 13, 2004 | 11:01 PM
red99svt's Avatar
Ya thats what i was thinking..I also riched it up alittle as well.. No pinging anymore but im still going to have it dyno tuned.
