Back from the track w\ported eaton...
Old Mar 13, 2004 | 02:49 PM
0light1's Avatar
I just got back from the track (1\8th mile)
I looked up my times from last fall with similiar times for a comparison.
It was right at 50deg. which is exactly the temp I had on the times from last fall.
I did run a best of 8.10. My previouse best was 8.12. I will admit I was hoping for high 7's. Is it possible to get high 7's on stock F1's?
Ok, the times:
This was on stock F1's no traction bars and pump 93oct gas. The only diff. is the ported eaton and the "last fall" times I had the lakewoods on. I did get some axle wrap so next time out I will put on the lakewoods.
TODAY (ported eaton): 8.10 @86.89 1.861 60'
Last fall (stock eaton) 8.12 @86.18 1.85 60'
TODAY (ported eaton) 8.22 @87.05 1.95 60'
Last fall (stock eaton) 8.21 @86.20 1.90 60'
TODAY (ported eaton) 8.16 @86.53 1.89 60'
Last fall (stock eaton) 8.15 @85.73 1.82 60'
These are the results. What do you all think?
Old Mar 13, 2004 | 02:55 PM
mrinaldi's Avatar
Good numbers man...From what I hear though, the ported eaton really shows it's stuff after the 1/8 mile with a strong top end charge...So get that truck to the 1320 and really see what it'll do...
Old Mar 13, 2004 | 02:56 PM
l-menace's Avatar
JUST TO CLARIFY
you did have lakewoods installed in the fall?
you did not have te lakewoods installed TODAY?
Old Mar 13, 2004 | 03:44 PM
Dman25's Avatar
yea, if u look at your numbers the ported eaton seems to be making a lot more high end power since, hence higher mph.
Old Mar 13, 2004 | 04:28 PM
0light1's Avatar
L-menace
That is correct. NO lakewoods today.
I had lakewoods on this past fall.
Old Mar 13, 2004 | 07:21 PM
thehammer's Avatar
Originally posted by 0light1
L-menace
put those lakewoods back on
and then lets look at your numbers
Old Mar 13, 2004 | 07:27 PM
Fast Gator's Avatar
Did I I that? At the track office sunday night?
Old Mar 14, 2004 | 09:05 AM
Rob_02Lightning's Avatar
Is Gator having trouble speaking again
Old Mar 14, 2004 | 10:08 AM
Fast Gator's Avatar
I, say,..........what's the difference?
I type in the dark
