Gear Ratio
Old Mar 4, 2004 | 01:18 PM
moses Black 01''s Avatar
Gear Ratio
I know this is a little off topic, but does anyone know the equation for calculating gear ratio (ring and pinion). I remember that it had to do with the number of tire revolutions and the number of driveshaft revolutions, but i can't recall it. Thanks
Old Mar 4, 2004 | 01:20 PM
dirtchicken's Avatar
Divide the tire revolutions by the number of driveshaft revolutions.
Old Mar 4, 2004 | 01:43 PM
thanks man
Old Mar 4, 2004 | 01:59 PM
No problem. After reevaluting my statement before I had any coffee it might be backwards. One will turn around approximately 3 1/2 times to the others 1 time. You'll have to check for yourself.
Old Mar 4, 2004 | 03:19 PM
georgia-SVT's Avatar
Mark the tire and the drive shaft count how many times the drive shaft rotates to one full rotation of the wheel. If yours is a 01 it should almost be 3 and 3/4 turns of the drive shaft 99-00 should be a little over 3 and 1/2 turns 411 gears will be just under 4 and a 1/4 turns and so on.
jeff
