Time for a Torque and H\P lesson!!!!
FYI Fellas,
HP is the inverse of Torque, that's how it's derived. If you check any engine, inline or V whatever the TQ and HP curve always intersect at around 5200 rpms. CE myself, but all you math majors chime in.
Shawn
Shawn
WOW, nice reading Doug BIG Thumbs Up
NOW THATS WHAT I'M TALKING ABOUT
THANKS FOR SHARING KD AND CONGRATS
Obviously we want both Torque + HP, it's a delicate balancing act,
so more of one, the other, or both WILL HELP. But what made me go with the Porting is instead of loosing power in the upper RPM ranges (or not gain any more) like all Dyno's show we do, this instead now carrys that Power AND MORE further up to higher RPM's. IT'S ALL GOOD.............
If your really asking ? Basically I have a Mutt
JLP Cool Air Induction Box (piped in Stainless, not flexible hose)
JLP and or JDM Hi Flow Filter used inside the box (I always keep a Spare)
Two Diablo Chips
Delta Multi Program Chip, Tuned by JLP (bought from RWTD)
Sport Chip Tuned by RWTD (bought from Motor Haven) (My Spare)
South Florida Pulley Headquarters 4lb Lower Pulley
SFPH Dial-Ur-Boost Quik Change Upper Pulley System
SFPH Gator Back S/C Belt
Wes's "WASP" (Ported Eaton) (Yes it's V's original Case)
REM 55/65/75 HP Zex Wet Nitorus System
PSP Nitrous Plate
LFP Polished Billet Accu-Fab Single Blade Throttle Body
JJ's Plasma Booster (Multi Spark Ignition by Ignition Solutions)
Chicken Man/G.Evans Factory Tech Valve Body (Bought from the V)
JDM 58" Bars (all former ET'S with PSP Truck Traks)
JDM Boost By Pass Kit (worth it's weight in gold 2 years ago)
Lightning Enterprise PCV System
PSP Drive Shaft Loop
Bought through PSP's Customer, 28x10 Hoosiers / 16x8 AR Rims
JDM Breather (currently not using, got new PCV Fix)
DJM 2" Lowering Shackles
LFP Lightning Front + Rear Badge Overlays
Chicken Man Bling Bling Radiator Cover (Bought from V)
Polished Billet Window/Heater/Shifter ****+Buttons (Bought from V)
Clarion 100 Watt Sub Woofer / AMP
Bla Bla Bla.......
Originally posted by kdanner
Oh and back on subject, I picked up just over 3 tenths and nearly 3 mph with the Apten ported eaton
Originally posted by 0light1
Uhhhhh Rob, what were your mods again
Two Diablo Chips
PSP Nitrous Plate
Bla Bla Bla.......
Uh NO right back at you, you're wrong. Did you not read my post? Go run on a dynojet without the RPM pickup, you get HP, you don't get torque. You obviously have never done this, I have.
I think you should go read your own post where you pasted in:
Many of you are familiar with the hp = rpm x torque / 5252 formula. In many situations, that formula is the way horsepower is calculated. In the case of the Dynojet dynamometer, it is not. The Dynojet calculates horsepower even if there is no torque reading
sometimes there is no torque reading, or the torque reading is faulty. This can happen because inductive and optical rpm pickups may not be perfect
post a smilely face when you showing the moderator "whats what " he did , be nice
Originally posted by Jim@JDM on 3-25-2001
First off, I would like to say that this will be my first and only post on this board.
BTW: that JDM post is pretty fricken old
Oh and back on subject, I picked up just over 3 tenths and nearly 3 mph with the Apten ported eaton.
sweeeet
do you ever go out to S.A.R. ????
No matter what happens on a Dynojet with the lead disconnected
Dynomometers measure torque and calculate horsepower...
Kdanner - you are absolutely right - I have never misconnected a dynojet to my truck to and gotten just HP reading... I would try to do it right if I could... LOL
Doug
Doug
Originally posted by shawnting
FYI Fellas,
Shawn
FYI Fellas,
Shawn
hp = (rpm x torque) / 5252
Your torque and hp will always be equal when your rpm is 5252. That is because:
hp = (5252 x torque)/5252
hp = torque
Now... what exactly is horsepower and torque? Horsepower is a measure of work. Torque is a measure of a rotational force. So, my understading of it is that torque is the what gets our trucks moving. HP is how much work is being done to move them over a given amount of time.This article appears to explain it pretty well:
http://vettenet.org/torquehp.html
One interesting quote in the article, although I'm not sure its acurate after reading the way Dynojet dynamometer measures horsepower is:
"Now, it's important to understand that nobody on the planet ever actually measures horsepower from a running engine. What we actually measure (on a dynomometer) is torque, expressed in foot pounds (in the U.S.), and then we *calculate* actual horsepower by converting the twisting force of torque into the work units of horsepower. "
Edit:
After re-reading the dynojet explaination, I do believe the above quote is correct. Feel free to critique this and correct me, as this is just my shot at it. I think I took everything into consideration.
Many of you are familiar with the hp = rpm x torque / 5252 formula. In many situations, that formula is the way horsepower is calculated. In the case of the Dynojet dynamometer, it is not. The Dynojet calculates horsepower even if there is no torque reading, and it does this in the manner that I am in the process of describing. Those of you that have had your vehicles tested at my shop and have watched the computer screen closely have seen that the computer plots out only the horsepower after each run, and I have to click the mouse a few times to get your torque. It does this because sometimes there is no torque reading, or the torque reading is faulty. This can happen because inductive and optical rpm pickups may not be perfect, and/or your ignition system may make things go a little haywire. If the rpm readings are not perfect, and the computer used the rpm x torque / 5252 formula, the hp reading would be inaccurate.
Work = Force x Distance
Now we get to the good stuff. Calculating the work is pretty simple for the computer. It just figured out the force, and it can easily figure out the distance because it knows the circumference of the drum and how many times it has rotated.
Power = Work / Time
We have an answer. Somewhere the computer factored in the bearing drag, and it throws some constants into those formulas to get the numbers to come out into the right units, but you get the idea.
Power = Work / Time
The dynojet does figure the hp... hp is a unit of power.
Power = Work/Time.
Work = Force x Distance.
So, we have to have some type of force to calculate the hp.
Force = Mass x Acceleration
In the case of a dyno, you are spinning drums. So your force is a torque unit of measurement.
So, the torque has to be found before the the hp is calculated.
So, then you can do the calcultions and find the hp. It is just another way of doing it, not the most common way. This would take out the error if your rpm reading was faulty.
Question is it a waste of money if after porting you have about the same dyno reading under same conditions as before porting the dyno should show any increase or has someone blowed this porting blowers completely inaccurate and i have yet to see that much of increase mabey it is not that noticeable of difference???
Re: IF THERE IS NO TORQUE READING AFTER PORTING S.C.
I think i will put a non ported supercharger back on my lightning
if i did not notice any difference sounds like i here an air leak ??
Doug
! No matter what happens on a Dynojet with the lead disconnected
Doug
Originally posted by reality1
And Just what does that relate to in e.t.?
Apten porting on a 00 blower I redrilled to the 01-up bolt pattern
used so called 4# lower pulley
Crown Vic electric fan - controlled by the EEC
Sonnax line mod valve
used Hoosiers
home built slapper bars
Tuned by me
Yes the airbox, exhaust, etc are still all stock.
Bottom line:
At any given RPM, if you gained torque, you gained HP.
At any given RPM, if you gained HP, you gained torque.
Because one is a mathematical calculation from the other, it is impossible at any given RPM to raise one without raising the other in a 100% exact proportion.
