First dyno run chart
Old Feb 25, 2004 | 07:05 PM
Sharpshooter's Avatar
Originally posted by fractaldragon
Never said they were accurate, but they are the only way to normalize to a certain temp and pressure. Otherwise, no one could compare at all to anyone else
My question to Red03SVT was; what was the Temperature and humidity. Your response was; that's what we have correction factors for.
Looking at that statement one would think that the SAE #'s are an accurate way of comparing our supercharged engines, sorry if I misunderstood you.
SAE #'s are only accurate on normally aspirated internal combustion engines. To my knowledge there is no correction factor for forced induction engines.
So when you say you see typically 340-350, and B-Man's #'s are within 2% of that, how can you say they are low? Being that the SAE correction factor could be the reason for the discrepancy. His uncorrected peak # is 341 RWHP. (341 X .98CF=334)
Please correct me if I am wrong.
Old Feb 25, 2004 | 07:08 PM
fractaldragon's Avatar
Uncorrected is 341 correct. But the 0.98 CF is the correction from STD to SAE and believe it or not STD is ALSO a correction factor itself...just a different temp and pressure....
Old Feb 25, 2004 | 07:10 PM
But still not a corection factor for a supercharged engine.
Old Feb 25, 2004 | 07:12 PM
ILLINI-SVT's Avatar
Here's my stock dyno run from a month ago - a 2002 with 2700 miles on it. Only non-stock item is a K&N drop-in - no airbox mods. Temp was 61 in the garage, very low humidity (middle of winter in Chicago).
I wouldn't hope that our difference is the K&N. Now I wish I had made a pull with the paper filter. I was pretty happy with my 353 rwhp 425 rwtq.
Old Feb 25, 2004 | 07:23 PM
All I am trying to say is there is no correction factor that is accurate enough on supercharged engines to make fair comparisons. I feel the #'s are a great way to compare your progress, but for me to try and compare my #'s to someone where the air is cooler and dryer, it just will not work.
-Mike
Old Feb 25, 2004 | 07:25 PM
B-Man's Avatar
Cool
I read on-line that on a "proper" dyno chart, the torque and HP plots should cross at roughly 5250 RPM.
Could someone explain why the graph ILLINI-SVT posted doesn't cross like mine does ?
Thanks in advance for any info you can provide...
Old Feb 25, 2004 | 07:28 PM
Mine crosses...
Old Feb 25, 2004 | 07:31 PM
B-Man
The HP and Torque each have their own legend on his graph. (HP on left side, TQ on right side).I think you are assuming that they are sharing a legend. If you look at the Right side the Tq legend starts at 350 and the power # starts at 250. They still meet at the right place.
Mike
Old Feb 25, 2004 | 07:32 PM
ILLINI-SVT's Avatar
Yeah, mine looks like it crosses just before 4200.
Hmmm. I hadn't heard that before. Does anyone have an answer to that? If those jobbers screwed up my dyno runs, I'm gonna be pissed.
I did 2 pulls that day, and on my other chart (351/421) they cross around 4350.
Old Feb 25, 2004 | 07:38 PM
ILLINI-SVT's Avatar
B-Man
Mike
Ahh, now I remember why I didn't pursue that trigonometry degree.
Actually, yes, it looks like they are actually the same number around 5250 now.
Thanks Sharpshooter!
Old Feb 25, 2004 | 08:14 PM
B-Man's Avatar
Cool
Good eye !! Thanks !!!
