Optimal A/F range for L????
Old Feb 24, 2004 | 03:18 PM
Learo2000GT's Avatar
Getting ready to go to the dyno to test some tunes and mods. I want to be real safe on the A/F range. What is a safe A/F range for our tracks??? where is it pig rich and where is it dangerous lean..... thanks in advance.
Doug
Old Feb 24, 2004 | 03:31 PM
TiresWinRaces's Avatar
You've opened a bit of a can of worms here, as everyone has a different opinion. Depends on boost you're running.
I would recommend nothing higher than a A/F of 12.2 in the upper rpm ranges at WOT. And even with that, I would run only Sunoco 94 octane.
To be safe, depending on gas available in your area, 11.8 is probably a safer limit. Below 11 and you are running pretty rich.
Old Feb 24, 2004 | 03:33 PM
01Lightning's Avatar
It all depends on how much boost and timing you are running. Safe ranges can vary from 11:1 to 12.5:1
Old Feb 24, 2004 | 03:36 PM
Well I have 92 octane and will have a 5lb lower.. not sure of the timming just told JLP to keep it safe for me.
Doug.... did not realise there was such a range.... Doug
Old Feb 24, 2004 | 04:01 PM
Shorty's Avatar
When you guys write 12.2 does that also mean 12.2:1?
Old Feb 24, 2004 | 04:15 PM
l-menace's Avatar
precisely
Old Feb 24, 2004 | 05:02 PM
moses Black 01''s Avatar
I run about 11.2 on my street program and 12.5 on my race program with sunoco 110
