Engine Rattle Question?
I have a 2000 L, Stock except for the cat back exhaust.
When the truck is warmed up and I'm sitting at a light I can hear a rattling noise coming from the engine compartment. If you put the truck in park or netral the sound goes away. It only does it when the rpm are below 600-700. As soon as the rpm's go up the sound goes away.
Any idea what's causing this? Should I be concerned?
Thanks for your help.
It's heard when the engine is under a slight(at idle) load and not at any other time............
May be a loose s/c belt and/or 'dry' idler pulleys? That's all I can think of now.
Dan
Dan
