Is there a way to re-set keyless entry code without the factory code??
Old Feb 21, 2004 | 10:00 AM
93Cobra's Avatar
If I don't have the pre-programmed factory keyless entry code for the doors, is it still possible to save a new numeric code to it somehow??
Old Feb 21, 2004 | 10:09 AM
Silver_2000's Avatar
the factory code is attached to module under the dash of the truck - did you remove it ?
If not just look up under the dash for 5 digit number on white box
Doug
Old Feb 21, 2004 | 10:18 AM
93Cobra's Avatar
This is on an Expedition that I was looking at. I didn't realize the number was elsewhere as I have only ever seen them on a card inside the owners manual. So I can find this code up underneath, and then use that to preset my code?
Old Feb 21, 2004 | 10:29 AM
Well let me back up
I have a 2000 lightning that DIDNT come with the keyless pad on the door BUT DID have the wiring in the dash and the door to make the right handle and keypad work ... In my truck and every other 2000 lightning you can look up under the dash near ebrake to find a white box or a white sticker with the code on it - It would make sense that other Ford trucks would be similar
That code is the factory code - you can then set other codes with that ....
Old Feb 21, 2004 | 10:39 AM
93Cobra's Avatar
Thanks Doug!
Old Feb 21, 2004 | 12:45 PM
denny0328's Avatar
from what i remember on my friends expy, the code was behind a peice of trim in the back of the cab, over the right drivers rear tire? if its not under the dash, maybe you could look there
Old Feb 21, 2004 | 02:41 PM
Mart Man 03 L's Avatar
The easiest, but not the cheapest, way is to take it to the Ford dealer and have them scan the computer to pull the code. When I bought my '03 Expedition, the card was missing. The service dept tech just hooked it up to the computer and ran through a couple of screens and got the code. You do need the original code to make changes. Hope this helps.
Old Feb 21, 2004 | 04:45 PM
LOCOSVT's Avatar
My '00 has the code under the dash by the HVAC controls.
Old Feb 21, 2004 | 09:52 PM
PS there is a details How to with more info on my website
It talks about both lightnings and expeditions I think
Doug
