Is there a rear clunk???
Old Feb 20, 2004 | 04:35 PM
VTSVT's Avatar
For the past month or so I have noticed that whenever I take a right turn that requires going over a slight bump, (like pulling into a drive way or a parking lot) I hear a loud clunk sound coming from the rear passenger side. Is this just one of the "normal" clunk noises we have, or is something F'd up? I crawled under there and couldn't really see anything obvious and I wouldn't really know anything subtle to look for. I do have truck traks on back there, but have only recently started hearing this. Any thoughts?
Old Feb 20, 2004 | 04:46 PM
Edward's Avatar
You know I've noticed the same thing. I notice it mostly if I'm making a right up an incline - like turning into a parking lot.
Old Feb 20, 2004 | 04:56 PM
AmoJohnny's Avatar
same noise here, i believe it happens when pulling in driveways, when the inside wheel is hanging almost or at full extension.
Old Feb 20, 2004 | 05:08 PM
foop's Avatar
I get a clunk quite frequently, but to me it almost sounds like the bed is clunking/sliding or something. I have a super steep driveway, and I get it when I'm midway out of the garage (rear wheels down the slope, front still in the garage).
I also hear it around corners every once in a while... I can't confirm if it's just on right turns or not, but possibly so.
Old Feb 20, 2004 | 05:40 PM
MaxTorque02's Avatar
Has the rear been lowered on any of your trucks? It could be the frame hitting the rear bump stop. If so, you could probably trim it down to keep it from hitting so easily, but it won't hurt anything unless you were to bottom out real hard.
Old Feb 20, 2004 | 05:44 PM
AmoJohnny's Avatar
just 2" shackles on an 03
Old Feb 20, 2004 | 05:47 PM
Rob_02Lightning's Avatar
I seem to have a little clunk too ???
Even know the Ranco Bars are hitting,
this seems to be a diff clunk ??
plus it seems to be from the Drivers side rear ?
I'm thinking in my case, I have to tighten up the Bolt that holes the Bar into the rear bracket, I think there's movement where
the bushing fits into that bracket
Old Feb 20, 2004 | 07:45 PM
foop's Avatar
Mine isn't lowered. The only thing that's been done to the rear-end is a bassani exhaust and a Line-X spray job.
Old Feb 20, 2004 | 09:21 PM
EZGZ's Avatar
Mine has it on left turns into a steep driveway or the like.
I am sure it is the frame flexing cause it is when it is in that 3 point stance sort of thing.
I did the clunk washers long ago. I am sure it is behind the cab.
Old Feb 20, 2004 | 11:57 PM
sbarkley3's Avatar
I have the same thing also. Mine is an 03 and also has not been lowered at all. Happens sometimes when I go over speed bumps too.
Old Feb 21, 2004 | 12:32 AM
01BlackL's Avatar
You guys sure the "clunk" sound isn't coming from the trailer hitch (if you have one) hitting the reciever? I have a clunk sound on bigger bumps, but I know it's the trailer hitch because I can move it around some and get the same sound because there is some slack.
If that is the case, some people wedge things between the reciever and the hitch, I haven't tried anything yet but its an idea if that turns out to be your noise.
Old Feb 21, 2004 | 01:00 AM
don presby's Avatar
Question
Yes!!! I also have one. I have gone over every inch of rear of truck,and not find anything loose top or bottom. I also have truck traks, a nd my bump stops have been cut 2 inches ?
Old Feb 21, 2004 | 04:49 AM
AmoJohnny's Avatar
Oh and I have a sound when i go fast over speed bumps.
Old Feb 21, 2004 | 09:58 AM
jimkalfakis's Avatar
I got the same thing going into a right turn into a driveway or something like that. It`s definitely behind the cab and also makes the CD player skip. It all started after the install of the Lakewood Traction Bars.
Old Feb 21, 2004 | 03:33 PM
LatemodelRacer2's Avatar
My rear clunks and squeks.
