Oil question
Old Feb 11, 2004 | 10:10 PM
stryker's Avatar
Oil question
I have an 01 with 38K miles.
I have an oil leak. The leak gets part of the oil pan wet, its not leaking puddles on the floor.
I checked the oil level about 2500 miles ago and it was fine. When I checked it Sunday it was 3 qts low. I am not smoking, and don't leave puddles where I park. Where did it go.
No mods.
Old Feb 12, 2004 | 01:05 AM
LatemodelRacer2's Avatar
I bet its in your intake. Take the rubber intake boot off and see if it is full of oil.
Old Feb 12, 2004 | 07:26 AM
stryker's Avatar
I will pull it today. If that amount of oil was sucked in, I would think it would smoke.
Old Feb 12, 2004 | 07:54 AM
01Lightning's Avatar
Could be the passenger side head gasket. Many '01 models develop this problem. I had mine replaced 15K miles ago due to an oil leak and "burning oil smell". Too bad your warranty just expired! Good Luck!
Old Feb 12, 2004 | 08:09 PM
stryker's Avatar
I still have 62K on the ext. warranty.
It looks like its not coming from the top, but just the pan gasket, that has been replaced before.
I pulled the boot, and it had oil in it, and the T/B.
Old Feb 14, 2004 | 06:03 AM
Rick Road's Avatar
01 Lightning have you had any oil leaks since you had the gasket replaced?
Old Feb 14, 2004 | 07:08 AM
Odin's Wrath's Avatar
Not three qts. worth.
Old Feb 14, 2004 | 07:51 AM
stryker's Avatar
I have had a truck or two that used/leaked more oil that this, but they had over 100K on them. Not a "new" truck using 1 qt every 1K.
Old Feb 14, 2004 | 08:23 AM
Not sucked in through the trottle body I hope.
Old Feb 14, 2004 | 11:25 AM
stryker's Avatar
No, the others have had carbs. This is my first s/c or turbo motor.
